Help with an Omega Da Ville
Hi all and thanks in advance!
I have just purchased this watch and would like some help. General wonders are it's authenticity, I believe it to be real.
Mainly I would like help on glass replacement, as you can see from the pics, the glass is awfully scratched and makes the watches condition look worse then it is. However I can't seem to open the back to find a serial number to confirm what glass I need, nor can I find any original Omega 22mm glass anywhere.
I also cannot figour out how to remove the strap.. Help with this would also be appricated. It looks like there are 2 clasps on the rear of the strap but they won't budge and it was actually starting to bend them with more force.
Any help, info or appraisal about this watch is highly appricated!
Harry.
Edited by HarryW
Looks authentic, but we will need a picture of the movement to tell for sure.
No reason to not be able to open the back, try harder. Also, ask Google what is 'spring bar' and how it acts, the bracelet is fixed to the case by 2 of them. But looking the condition, probably the bars must be cut as they are 'glued' forever with dirt. The other option is to remove the movement and soak the rest in some solvent or degreaser for several days... he crystal can be replaced with generic acryle domed crystal with proper size. Serial number will help to date the watch, but will be useless if parts searched - this is not a car.
By the way, why did You bought it?
Edited by nevenbekriev
Hey!
Thanks for your reply 🙂 it's not that I haven't tried, it's more that I'm worried I'm doing it wrong, does the back just need to be pride/flipped off?
I shall do some research on the spring bar part, thank you!
I bought it as its a nice little project to fix up and then gift to my partner. Hopefully it will keep/increase it's value over the next 10 years.
17 hours ago, RichardHarris123 said:
Good advice, remove the back, it's a snap on.  There should be a notch to put a case knife or thin blade in. We can advice how to remove the movement and then you could soak the case and bracelet together.
Thank you!
Once iv gotten the back off I shall do another post asking about the movement. 🙂
    • Maybe you had a bad one H, the cheap blue one i use has been fine for nearly 3 years now. It demags enough to stop the tiniest of screws sticking to the carbon steel tweezers i use. If it were to fail at some point in the future i very  probably would go up a level of device just because.
    • Lot of “industrial “ de magnifiers on Aliexpress  https://www.aliexpress.com/item/1005004699640024.html?src=google&src=google&albch=shopping&acnt=708-803-3821&slnk=&plac=&mtctp=&albbt=Google_7_shopping&albagn=888888&isSmbAutoCall=false&needSmbHouyi=false&albcp=17858129175&albag=&trgt=&crea=en1005004699640024&netw=x&device=c&albpg=&albpd=en1005004699640024&gad_source=1&gclid=CjwKCAjwo6GyBhBwEiwAzQTmcxIEVpMt1vFIKQyfjVwT95zrBsOi5dt-GgFOmLamBcMcu4tO7CfaaxoChnEQAvD_BwE&gclsrc=aw.ds&aff_fcid=b7140f118e144db7876d074872aec9cb-1716029308364-08531-UneMJZVf&aff_fsk=UneMJZVf&aff_platform=aaf&sk=UneMJZVf&aff_trace_key=b7140f118e144db7876d074872aec9cb-1716029308364-08531-UneMJZVf&terminal_id=6b7c60e41b044cb39d1431f62cda0958&afSmartRedirect=y   a hard drive wiper/degauser would also be worth looking at.   Tom
    • Unfortunately yes! Magnetism can wreak havoc on a mechanical watch movement if the balance hairspring becomes magnetised. The cheap blue Chinese demagnetise-rs are useless if you feed them the wrong voltage (> 110 V), and even so, they don't work very well. The one I got when I was new worked so poorly that it drove me nuts. Eventually, I was lucky to get a Greiner Magnomatic for a little money. It's an amazing tool that can be trusted to do its job perfectly in seconds. A new one comes with a price tag of  £885 excluding tax and shipping, and if you think that's a bit steep (I believe most of us would) and can't find a used one I'd go with @Jon's recommendation.
    • Yep Mike , i use exactly the same gauge for it.
    • You definitely pick up different names from different people of all ages from everywhere. Like learning different dialects of the same language. Its all part of the learning curve of any trade.  Both those two terms describe to me perfectly that they are one and the same. After a couple of years of knowledge you can figure out what is being talked about. There are times that i get caught out with something i haven't encountered before.
