Newbie needs advice
This is my first time taking a movement apart. I ordered a Hemobllo st36 movement to practice on. After taking it apart and putting it back together a few times, I have an issue. The last thing I took out and put back on (several times now) was the hairspring balance. Now for some reason when I turn the movement right side up, the balance slows down and stops. As soon as I flip it upside down, it works again. All the pivots seem to be in place. I did not lubricate anything, as I am still practicing taking it apart and reassembling. The hairspring is not bent and does not seem to be touching anything. I can see all the pivots spinning.
Hello and welcome to the forum, as Richard said. We need pictures. In the mean time when you dismantled the watch did you remove the balance jewel settings, if you did then I would inspect them both for correct replacement of the settings and the cap jewels and also the spring is set properly.  Just for starters.
    • Hmmm you know when i said some damp might have caused the bubble originally hmmm 🤨
    • Are you all jerking my chain, I'm a yorkshireman £4.04 is too much 😆
    • [Myota2034] Custom simple quartz watch — PricewaterhouseCoopers On a very very different note, here is a watch from approximately 2000 when I was a Partner with PwC, Management Consulting. It was a simple “marketing watch” with a clever “vase of knowledge” that is subtly revealed on the dial as the second hand progresses. Clever for a simple watch!⌚️
    • I think someone else has though. Some where here using a modified perspex sheet. I may be wrong i may be right , i think it involved fitting the arbor to a pin vice. I dont have experience of the bergeon winders, are the handles not interchangeable ?
    • Never tried dial dots, i always considered them as a bit of a bodge.  You are adding something that was never intended to be there. I wonder how the adhesive reacts to any part of the movement, hot summer heat and i think things might turn sticky. Most adhesive backed stuff has a tendency to soften and slide around so it may spread, i have used a lot of so called sticks all adhesives in my industry that are just not up to the job. I suppose they get you out of a problem quickly, but how permanently might that be ? I would just explain to the owner that it may or may not work. WWs other ideas are a much more permanent solution but both have their risks . I've tried milling and dial feet replacements, hmm it was ok, ive heard of folk dimpling the face , so that needs care . And i have soldered a few times , all with good results but i am very careful and I practiced it a lot.
