1950s Seiko Marvel Balance Staff
So how would that give you the end play from the screw down crown? That is a bit on the pricey side. I wonder if it's possible to drill the second hole yourself in a normal split stem?
Can't you solder male and female parts of the stem together, it'll do as a one piece stem.
By Michalzeszen · Posted
Unfortunately, I couldn't source the correct part from the old folks. I did find this: https://lobtime.com/shop/ols/products/screw-down-crown-kit-set-of-5-for-titus-calypsomatic-diver-watch-technos-skydiver-fayt It is much more than I should pay for a set, but it is interesting to see that someone is producing it to keep up with a somewhat rare demand.
