Croton Aqua-Medico unknown vintage
Hi and thank-you for your suggestions, as per Mark's instructions I checked my browser "Safari" and spell check and grammar was not ticked. So all sorted. Thanks CJ
As an alternative, clear nail Polish, the advantage is you can have a manicure at the same time. -
I use Grammarly. It works really well and If English is not your first language, you will also receive help with formulations. There is a free version that covers most of my needs. It installs as a plug-in and works with all browsers and word processors.
The traditional glue for crowns is Threadlock Loctite. I use Loctite 290. It holds the crown well and when the crown needs to be removed you can just heat the stem a bit and it will come loose. Perhaps the blue type has some advantages?
So firstly this book was first wrote almost one hundred years ago. Secondly Emil Borer was more likely in charge of design and research at Aegler's factory, the factory that Rolex claimed belonged to them, but Gruen also apparently made that same claim. And lastly Emil Borer was way way ahead of his time and very very probably knew exactly what he was talking about. You must be on tenderhooks to read page 25 ? I'll release it mid July 2024 🙂
