This watch was worn long after the retainer ring broke. I'd like to keep the ring for authenticity but where the ring is broken there is very little material to work with. The material is so thin but I did sand it carefully without deforming. I'm thinking of a careful application of the soldering iron since there's no surface for a copper bond or epoxy but I'm not certain solder will take either. As one French YouTuber would say, it is sooo small!  What to do you think?
It is sooo small...
It's been rubbing in the case and there's damage on the dial, too...
