Hi All,
Just thought I would post a few pics of my restoration project of a Seiko 6119-8083 I picked up off ebay. It was pretty scuffed up but the dial looked ok and the seller had decent pictures of the movement.
Once I opened it up the dial was indeed in near perfect condition and the lume was still going strong despite its age! I wanted to get this looking as "new" as possible so gave the case a bit of attention and popped in a new crystal.
I only noticed after it had all gone together that the day-disc is offset; it does not feel loose so I suspect it was taken from another watch with a different crown position.
Overall, Im really happy with it.
  • Like 5
Expand
I would agree that the date disc is probably from a different movement with a 3 O'clock stem position and not 3.4 position, what also gives it away is that the day disc is white and the date disc is black, so I'm 99.99% sure they are not a pair. Fortunately it's a quick fix to switch out the disc, maybe from a donor 6309 (I assume they are compatable?) movement which you can pick up quite reasonably for less than £12 - link Here or less than £6 on the same site for just the disc.
    • The make do stem has a turned round shaft at the bottom, a little higher is the square but slightly tapered shaft, this fits in to the setting mechanism but only friction tight. The stem isn’t long enough to go right through the case so can only test and wind out of the case. In normal position the stem winds and if you push the hand setting lever (at 4 position) this separates the setting mechanism and the hands can be set, pushing the same lever back disengages it and it goes back in to the normal position. im unsure how the stem in this movement is prevented from dropping out, there are no threads in the crown shaft for a screwed sleeve.
    • Yep…This makes perfect sense. With that large a gap in the serial numbers, they were almost certainly machined on different equipment, hence one should have no expectation of any cross-batch compatibility. I’ll revert to the original bridge. Regarding bending the bridge @nevenbekriev, I’ll give it a try, but I may have to buy some better calipers. My Vernier calipers are only accurate to 0.1mm. Not very accurate.
    • Yes, what I wanted to say is that the cock is part of the main plate, manufactured together with it and not meant to be interchangeable. Even if the other cock gets in place, it is not sure that the balance then will stay upright. You should use the original cock when it exists and is not destroyed. The adjustment needed by bending it is not irreversible. It is minimal deforming that is needed. No tools are needed. I have pointed to all needed references here for the balance staff endshake checking and correctness confirmation. The only tool needed for the correction is You thumb. The cock must be fixed on the main plate, no need of special plate with holes and so on. If You will feel more confident, then measure with Vernier caliper the height of the top of the cock where the stones are against the main plate bottom when the shim is fitted and try to reach the same height when bending the cock (with no balance in place!!!) Caliper with screw for fixing is perfect.
    • Thanks for the reply. I polished the head of the screw using 1500 to 10000 lapping paper and a screw polisher. This is why I think the head blued and the rest of the screw didn't. Silly question, how do you polish the whole screw inc threads, if that's what it needs to blue? 100% clean, Elna red and heated ultrasonic bath + IPA rinse. Finally, there is definitely heat leak as there's about a 30c difference between the brass bed and the soldering station temp. Having said that, the bed temp was stable. I will try to search out a better brass pot, but I haven't found one yet, hence the stainless steel bowl.
    • Agreed but that's where WD40 excels, water displacement.
