I have a Visitor Linden (Miyota 9015) that needs repaired. I'm not quite sure of the problem, but it doesn't wind the movement anymore when I wear it; likely something
to do with the rotor. Also, something like a screw or a part also sounds loose when you shake it close to your ear.
Any recommendations on a reasonable and honest watchmaker to service it?
How much does/should it cost to repair or replace the movement?
I'm ok shipping it out, but I'm also reasonably close to the Atlanta area.
I'm ok shipping it out watch repairs, but I'm also reasonably close to the Atlanta area.
really appreciate any help. thanks in advance
Sounds like a loose rotor or winder module, perhaps bad bearing/ worn axle.
Do you have tools to remove the back plate and a screw driver?  we will work with you to fix it yourself.
Edited by Nucejoe
