Hello,
Occasionally I nosey at existing project watches and movements. Eventually it would be nice to try getting this going - at a casual look I suspect it has a problem with the escape wheel.
I'd like to get a better idea how complete the repeater work is, and what might be missing. Identifying the maker might help.
The dial is unsigned, it looks unsigned under the hammers, and there's no obvious logo anywhere. The motion work is partially removed but it's otherwise as-found.
Thank you
Jonathan
I should probably add, the chronograph is incomplete, but much less of an issue.
27 minutes ago, RichardHarris123 said:
Wow, cool watch. Do you have the case or just the movement?  What does the script say above the cross, I can't make it out?
Depose, it tells us of something registered with the movement . The cross is usually accompanied by the   word Brevet which means patent. So something about this movement's design has a registered patent as opposed to before its registered a patent pending. There may be a serial number to go with it that can be looked up to find out what that design is.
Ah another look didn't notice the US patent date. At least we know the watch is no older than 1882. Registered in the U S yet the mark and french for patent, i wonder how that works ?
Unfortunately there's no case.. the movement is huge so I suspect it would have been gold. I bought it from an Argentinian eBay seller a couple of years ago.
Interestingly (to me at least), the unsigned dial originally had feet, but now stays fitted with a friction fit ring on the back out it.. so I wonder if it was an ebauche intended for some slightly different repeating work, or whether it's just a tidy re-dial.
After some time.. partly because I was initially trying to match hairspring studs to find the maker, I found a very good match, A Lugrin 🙂
The patent date is the giveaway, and curiously, while there were a couple of Lugrin's in history, one of them was responsible for a patent used by a couple of makers, including on the Waltham pocket chronograph watch. I believe this movement was made by the Lugrin which became Lemania.
(I hope I'm alright linking to another forum)
https://mb.nawcc.org/threads/adolf-lugrin-minute-repeater.99313/
    • Welcome to the forum. You're best starting with something that you know runs well and keeps good time. That way when you've stripped and service it, any problems are due to something you've done.
    • Welcome to the WRT-Forum! Sorry to say it, but you’re very likely to break or lose something when servicing a wristwatch for the first time — I’ve been there! So, if these watches have any value to you, don’t attempt to service them as a beginner.
    • In writing "shimming the staff" I was alluding to the idea trailed in the above referenced thread of inserting a hair along the staff which, as the discussion there covered,  could result in some eccentricity. By making a (more or less) complete cylinder I was hoping to avoid that problem. Don't tell anyone, but needing a very ductile metal to do this by manipulation at such a small scale, I used a piece of an empty Tomato pureé tube! It occurred to me that the material's ductility(?) would also put less stress on the RT in forming a sufficiently tight seal. Anyway, that's how I avoided the temptation to use glue. No doubt your punctuational response to this confession will be "!!!" !
    • Hi All. I would appreciate some advice for a complete newbie on getting into watch servicing - nothing serious,  just as a fun project. I've got a thing for hand-wound watches and would like to bring an old watch (or two) back to life, so looking to learn to do a strip-clean-oil-assemble cycle.   I've toyed with this idea in the past (years ago) and picked up a couple candidates to learn on, but never found the time for them.  One is an old Ingersoll, swiss-made 17 jewels. It seems to wind and tick. Casing, dial, glass are in great shape, so looks like a good candidate to me for the first service. The other is a Benrus DR23. It winds and makes a few reluctant ticks, but then seems to stop. Casing looks like a complete gonner, and the dial is in pretty poor shape too. If the movement is not broken and just needs a service, I wonder if there's any possibility of getting a cheapo Chinese casing & dial to fit this movement in, or is it extremely unlikely to be the right size?   For a start, I want to strip & assemble a movement, perhaps a dozen times to build up the basic parts handling skills. I see that online advice is to buy a Chinese-made ST36 for this purpose. Can I just go at the Benrus or Ingersoll instead, or does it make more sense to get a cheap ST for this? Thank you.
    • Hi,  I have this vintage Navitimer 806 with a bezel that plays a little bit as shown in this video: https://imgur.com/a/2NjdiF0 How would you fix this? I don't see where a gasket would fit for instance. Also, it seems this issue happens sometimes with older Navitimers.  Thanks
