DIY Cleaning Machine
With something like this I expect you will have to make one yourself or have it made for you.
Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement. This might be helpful 704789946_TZIllustratedGlossary(2).pdf
Will barby get hot enough ? the heat needs to reach around 800°C to disrupt the magnetism. You can always chuck a couple of burgers on it though. -
By rjenkinsgb · Posted
The setting could have been silver plated? I doubt it would be solid silver. I initially tried various liquids for cleaning, with pretty mediocre results. Eventually I forked out for the gallon-size containers or L&R #111 cleaner and #3 rinse. That stuff, cold, at three to six minutes a stage in the ultrasonic, works superbly; the results are immaculate even on things that are disgustingly bad when they go in.
