Omega Geneve - a nerve wracking restore for a good friend.
By LittleWatchShop · Posted
By SwissSeiko · Posted
Lubed up, back together (minus the one screw), and I'd say not a bad result! Going to give it a day or two to run in while I clean up the case and regulate it again, but off to a good start.
