I have a J Calame Robert pocket watch that I am trying to service.  I've got the entire thing disassembled except for the center wheel and cannon pinion.  My trusty Presto tool was completely useless in this situation.  That cannon pinion is absolutely stuck on there.  I tried turning the movement over so that the center wheel was facing upwards, and I tried to maneuver my hand levers between the center wheel pinion and the movement plate.  I could tell that the hand levers were going to start to bend before the center wheel arbor was going to move.  I stopped so that I didn't break anything.  I tried a drop of oil in there to try to lubricate it, but that didn't help either.
My next attempt will be WD-40.  Does anyone have any other suggestions to try?
I'll try the pin vise.  But w/r/t the scalpel blade, I fear that that would be pushing it off to one side instead of somethign like the pin vise pulling equally all around.
Update, tried the pin vise. It just slid off.  Tried another pin vise, also slid off.  And I really cranked it down as hard as I could.
Then I tried my staking set to gently hammer the arbor out of the cannon pinion, but it wouldn't budge.  I left it soaking in lighter fluid for now maybe some gunk is gluing it shut.  If that doesn't work, then rust remover or WD-40.
12 minutes ago, Malocchio said:
How about acetone and ultrasonic?
I wouldn't directly ultrasonic acetone since it has a much lower flash point than lighter fluid, but I can certainly try a soak.
Are you dealing with this type of cannon pinion?
As opposed to the normal type?
from Fried’s Bench Practices
Edited by JohnFrum
Hi John, is there a way to distinguish between the two without trial and error?
Sure, flammable liquids should always be put in a glass container that goes in the ultrasonic water bath. That's how I use IPA. Also, the acetone fumes would be pretty brain melting if put straight in the tank.
Got zero experience with this but the head of the tapered pin should be distinguishable under magnification.
You don't need trial and error you look at it And instantaneously recognize it like I do. What are the clues? Notice the shape of the cannon pinion How solid it looks doesn't look like the normal kind and there's no place to grab it's very smooth. Then notice the protruding pin on the dial side that's your other clue that's the pin that you have to drive out. Then your images and good enough for the other side to see what we need to see.
Then I would put the plate back on holding the center wheel before driving the pin out. That way you'll avoid damaging things.
Then because this is a relatively common question I have pictures. The notice in my pictures I have two separate types. The easier to recognize because it has a squarehead it's a key set watch. The other one they just looks like the end of the standard large pivot kinda like yours. It's really hard to see where the actual head part is you should bill the CRs if you look really carefully.
After using the ultrasonic, I was able to see the seam between the center wheel and center pin, confirming that it's not the usual cannon pinion setup that you normally see.  The ultrasonic must have cleaned it up enough to loosen it, and I was able to stake out the pin.  Thank you for your help.
    • What's the movements so we know what size cases you're looking for and what are the setting requirements.
    • As I am getting close, I would like to know the total thickness of the bezel (top to bottom).  I am working on two solutions--one is thinner than the other.  The crystal sits pretty proud relative to the bezel, and seems consistent with the pictures I have seen.  But, actual measurements would be nice.
    • A little bit of superglue and you'll be good to go Although maybe if you had a laser welder you can weld the spring back together. Typically I've only seen it on blued steel Springs and on one occasion a modern spring? The modern watch was a Rolex watch that came and that was literally filled with rust including the barrel was filled with rust in the spring was in a whole bunch of little pieces. I have to wonder if that was an aftermarket mainspring . Then I'm attaching a PDF the Elgin watch company as you can see instigated a study in the 30s find out why mainsprings were breaking. I do though wonder if perhaps there may be a flaw in their study? One other things I wonder about is the metallurgy of the early steel Springs versus the later generation of blued steel Springs whether the metallurgy as part of the problem but in a case they did a study and have attaching a PDF. Because of the study any time I do anything with the blued steel spring when I actually cannot get something that's not blued. Once the spring is cleaned I'm very careful to not to touch the spring with my fingers because I don't want to have a problem with the chemicals on your fingers causing rust and I very carefully get lubrication back on the spring as fast as possible just to avoid these unpleasant situations. Then yes it is interesting one minute you of functional spring and the next minute you have lots of little pieces of spring. For my own personal Elgin pocket watch I put a steel spring and in this happened I'm also guessing that when one layer breaks it sends a cascading shockwave through the spring and that's why it breaks all the way across because after all there is a lot of energy in the spring when it breaks. Oh and my theory on the metallurgy is based on things have improved and for the most part I don't think I've seen a shattered spring in quite some time.   Elgin_Mainsprings.PDF
    • Hi all A bit of an off chance one but has anyone got any links to suppliers of Conversion cases, to adapt pocket watch movements to wrist watches. I have a couple of movements and bring in the UK there is little chance of finding a replacement case so thought about converting them to wrist watches, I have seen loads of converted watches for sale so there must be a supplier somewhere, anyone know of a supplier. Thanks Paul
    • Thank you very much. I routinely harvest these strips so will be able to attempt a repair - much more interesting & potentially satisfying than acquiring a new replacement item.
