Can you nickel plate over gold plating
Levine98
I know that seems backward, but I have an old case that is 10k RGP and I want to nickel plate it. I’ve done this before, taking the gold plating off down to the brass. But this case has lots of irregular shapes that make sanding really tough. I’ve tried to get the plating off by buffing with black cutting compound, but not much progress…).
So I’m wondering, can you just nickel plate over gold instead of having to get the case down to the brass base?
I don't know, but I would love for you to share your nickel-plating process!!  Maybe do a video???
I’m not equipped to shoot video but there is a ton on this subject on YouTube. For example Wristwatch Revival most recent episode shows how to nickel plate in prep for gold plating (I mimic his setup with good results).
Edited by Levine98
    • Here is another option, if you have the patience to sort through the parts you usually find 50-100 screws as well as some other cool stuff. Most times I get an order from these guys I get a 250g box, takes a few days, but end up with hundreds of spares and all you need is for one of them to be useful and it pays for itself. Also helps hone your tweezer skills!
    • As Hector said they have too much  tension, that tension is also fixed and not easy to control. Conventional tweezers have infinitely variable grip provided by us.
    • Thank you and i appreciate that, it looks very different    Thank you sir but i think there is a little problem according to that reading it's because it is far different to the other move that i serviced, i will atouched the photo. They are different movements but this one is 7s26b movement and they are also different in shape when it comes to the ballance assmebly. Thanks also for the concerned i appreciate that.
    • Donor movement showed up, so I stole the bridge screw from it. Which made me sad, because it's in such nice shape! It seems a shame. Maybe I'll find a use for it one of these days. Unfortunately, the stem is for a different style of case and is much too short. Fortunately, I ordered a brand new stem from McCaw Company. Unfortunately, the crown on the donor movement is thoroughly stripped out (it unscrewed in a shower of brass) so i just put the old stem back in for now until I source a new crown. As you can see, it's just a little too long for this case. Overall I'm super pleased. I didn't think I'd like the bracelet, and even that is growing on me.   Anyone have a favorite crown assortment?
    • A couple of pictures of the front… Sorry, I’m months away from this one, but…there is an edge to the bezel but I see no obvious signs of previous bezel removal and it is quite thick so it would be difficult to grab an edge on the crystal with a crystal lift. It does look like in/out thru the back…good luck…
