Help on Seiko 4205-0155
Hello Ladies & Gents, how are we all today. Very well I hope....
 This is my first auto movement service! And when I removed the oscillating weight and its plate there was a jeweled spring underneath(picture attached)which was dislodged when I picked up the plate and I am not totally sure how it goes back!!! Exact position? Which way around? etc...
 Please is there someone that can help me with this? Be hugely appreciated. I like to ask first rather that far around trying to place it & damage something!!!
 Many thanks to you all in advance....
David....
4205 is a fiddly little thing isn't it? 🙂
That 'spring' isn't actually a spring. It's the magic lever, which is what turns the oscillating weight movement into an action that winds the mainspring. If you look online for Seiko 4205A you should find a schematic without too much difficulty. In fact, here's one I found for you:
https://www.cousinsuk.com/document/search?SearchString=4205
But looking at the doc it doesn't show what you need. Instead, look at the 4205B and you will see how it all goes together.
Hope this helps.
Hello Sir, thanks for the swift reply and it definitely helped. But(there's always a BUT)I am a little unsure about the friction spring for sweep second hand now! Does the Awl lever just sit on top of that as it covers the centre hole below where the Awl lever jewel is? It's shown in the pictures I added previously...
 God, I wish the Awl Lever stayed in place when I lifted the plate up! Would of saved much hassle. But I guess that's the beauty of it. Overcoming problems...
 Many thanks, David...
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
