storing Bergeon B dip
Hi folks
Hopefully this is a quick and easy one! so I bought some of the above, have tried to keep it in 2 different jars but the fumes seem to melt the plastic tops (one was a food pot, one was a an empty cosmetic jar donated by my lovely wife)
What does everyone use????
Thanks for your time
Dunc
I don't use B Dip or its predecessor one dip, I use Essence of Renata and keep mine in what are essentially small Jam Jars and see no evaporation between uses, the metal lids have some sort of rubberised seal which is not damaged by the Renata, this my also be fine with your B Dip.
I get mine brand new (so no jam residue) from my local craft store (Hobbycraft) for a pound each, they do all different sizes, I went with once size up from the smallest.
Edited by Paul80
    • Never seen that but yes very practical Hector
    • Welcome, Simeon! I'm into Soviet watches too (not the political system, and yes, I am able to make the distinction, unlike some). They offer amazing value for money. I like your "Big Zero" profile image. It's a true classic and I have one of those myself. I noticed that the hands aren't the original. Not that it matters a lot but here's an interesting article about the Big Zero if you haven't already seen it.
    • I was thinking will the gasket stretch at all to match the desired size.  Did i also deduce that the original gasket is thinner (0 .5mm ) than the cousins gasket ( 0.8mm )  could that just be an effect of you measuring the case for the gasket size  H  ?
    • if we look at and understand why steel becomes magnetised and unmagnetised then its possible to work out why some devices are better than others. Simpy it is a parallel alignment of atoms , electrons within a material caused by external magnetic fields. Different magnetic fields cause different alignments and non alignment of atoms. Fields by AC currents are changing atom direction approx 50 times per second ( 50hz ). As a material is drawn away from a demagging device the field is becoming progressively weaker while also changing the material's atom direction having the effect of returning their random directions ( demagnetising ) . To improve on this demagetising effect, try changing the material's orientation as it is drawn away.  Fields caused by DC currents have the most permanent magnetising effect as the currect is flowing one way only. A good demagger would produce random magnet fields and disorientation of the material's atoms.
