Showing results for tags 'watch poising'.
I am continuing with my restoration of early IWC Cal. 64 and Cal 64T watch movements. Even after cleaning and oiling the timing is often out by more than the index lever can accomodate. Today the movement was running slow, however, the timing screws on the balance were each 3 turns unscrewed. This provided me with the necessary adjustment to increase the beat rate. But it can be a fiddly job, particularly for my unsteady hands. Here is my solution - a small clamp to hold the balance while I turn the screws with a 0.5 mm Horotec driver : The base is milled out of Delrin (Nylon), the finger clamp is from copper-beryllium shim with a thin leather lining on the balance side. The screw-down piece is made from a from a pocket watch stem and crown. Here it is under the x20 binocular microscope with perfect vision and access to the timing screws.
- 14 replies
- 2
- Balance screws
- dynamic poising
(and 3 more)
Tagged with:
