Hi all
I am ready to strip / service and rebuild a fusee silver pocket watch and I need a set of hands.
The seconds hand is at 6 o'clock the size is 6mm from centre to tip - total length 9mm. The bore is 0.305mm on my micrometer. The hand width is 0.2mm and is straight. The tube length is 3mm. The seconds hand in the pic has an oversized tube bore and has been crushed at the tip to grip the seconds wheel arbor. The tube rubs on the dial because it is oversized and stops the watch from working. Removed the watch works fine.
Any help would be greatly appreciated.
The minute hand is spade with a square bore 1.4mm square. Centre to tip length = 18mm
The hour hand is spade with a bore diameter of 2.5mm. Centre to tip length is 14mm
Can anyone help me obtain these hands or tell me where to get them from?
Thanks in advance.
Steve
