Showing results for tags 'doxa 300t'.
Found 3 results
  1. This is one of my first watches. I own it for more than 40 years and I stored it for years after it fell and the crystal snapped. Seven years ago I decided to restore it . I went for two or three watchmakers for an estimate but In the end I decided to do it on my own. Had to Redial/Relume, find a new crystal, gaskets, hands, bezel spring and movement overhaul. Took me a while and finally finished it a few weeks ago. I’m very pleased to wear it again (though I’m not planning to dive with it) The original watch looked like this: There was a lot on my list: There were scratches on the dial and the black lost its depth, The lume was in bad shape (though the lettering was better.) The hands were missing, and I had to find something that resembles the original hands (“Hens teeth”) The Mineral Crystal broke long ago and I had to find crystal and gasket(s) The rotating bezel had to be polished and repainted. The bezel click spring was missing. The crown gasket over the years became black goo and had to be replaced. The crown tube gasket was missing (I didn't know it at this point) The movement was in fair shape, but has to be serviced. As I wrote I decided to do it all by my own after I received several estimates from watchmakers (I guess this was my intention from the beginning but I didn't have the know how nor the confidence.) Took this as a project and had to dig for information. Since there are few versions of this watch I had to find the right info. Some restored a similar but not the same version and I had to dig for the right info. The dial: I sent the dial to Robert Miller at international dial company. He told me he has the original dies for the “professional” sub (The orange sub) for this watch he had to change it to sharkhunter. (this was seven years ago, now I see the company changed its location and website) You can compare the before and after. The Hands As the original hands were lost, and there are no originals to be found.I Found very similar ones at Yobokies. This sub uses Eta 2472 movement (aka doxa 118), which uses the same hand size as seiko. Yobokies (and dagaz) sells seiko mods, one of them is the soxa mod or axos mod which mods the seiko to look like the doxa sub. The ”soxa” hands looks very similar to the sub’s hands. Since they were meant for slightly bigger dial, I had to shorten the seconds hand. I was also happy to see that the lume color on the dial and hand were the same. The crystal and the crystal gaskets. Since the crystal broke years ago I had to find one that fits. I was a little bit confused from what I saw on the net until I realized there are few versions of the sub. In the synchron sub for example (A later version of this watch- from the time synchron company purchased doxa) the crystal is a thick flat mineral glass. It is inserted from the front and held by a thick visible orange gasket. In this version the the crystal is a stepped glass, 3.6mm thick approx, it is inserted from the back of the watch and held by a screw in retainer ring, with no visible gasket. Because it is not manufactured anymore, some watchmakers produces a close clone by bonding two flat crystals in different thickness and size. This guy on the bay produces this crystal by copying an original one(as he said). He posted it as a “DOXA SUB 300T Sharkhunter” crystal unaware of the various possible versions for this title. At the time I wasn't sure it will fit mine, so I made one using the watchmakes method by bonding two crystals to one using ultraviolet curing bond. At the same time I was looking for a fit gasket when I stumbled on a post in this forum . Now You can’t see the original post’s images, but in this image (from the post) I found that the Crystal was held by two (probably the same) gaskets (the gaskets on the center of the image). Ordered some gaskets in various possible sizes and choose what fitted best. The gaskets fits the inside of the watch and around the wider bottom side of the crystal. It is all held by a screw-in retainer ring. (bottom left ring in the image above). Can’t tell if this was the original design, and I didn’t make any pressure test (yet) This is the crystal and gaskets I used: The rotating bezel At the time I didn't notice the bezel has polished and brushed parts, so I polished it all, and colored the marks and numbers using nail polish lacquer. On the luminous dot I used epoxy glue mixed with luminous powder. It was one of the first things I did on the watch and left it as is. The bezel spring Had to create a new bezel spring following this post. I used dentist's 0.8mm stainless steel wire but I wasn't sure what of the exact wire girth, so I ordered from AliExpress various wire sizes. Made this spring. It's not perfect but it's doing the job. The crown gaskets The original crown gasket became black goo long ago. Couldn't find any information regarding this screw down crown. The closest design I found was Rolex twinlock crown . From the shape of the crown and tube I assumed the possible sizes of both case and crown gaskets. I ordered some possible gaskets sizes and used the ones that fitted best. I added even one more gasket around the case tube to imitate the Rolex triplock (obviously unnecessary...) The Movement In this watch doxa used the Doxa 118 movement - a slightly modified eta 2472 movement. The movement had to be serviced. On some point on this long period I decided to service it on my own. It was the most intimidating part of this restoration because I had to learn this from zero. Bought some old movements on the bay for cheap, bought some required tools and started to take them apart and rebuilt them again. After I gained some confidence I did it on the doxa. I made some damage but found the right replacement parts (One of my discoveries was that movement springs tend to fly and disappear while flying…). It took me longer than I thought. For couple of years I left it in the box, but the covid19 period gave me little time to get back to it and finish the job. more to do Need to regulate the watch, probably after I will build a proper timegrapher mic. Maybe pressure test: just to check how waterproof is it. I’m not planning to dive with it. Bor bracelet: maybe yobokies. found this on alibaba but minimum order is 200… Thanx Gabriel (This was also posted on Watchuseek doxa forum few weeks ago)
  2. Hello to you all folks, thought I should share this story with you ,,,, Then I finally completed my big project "Doxa Searambler 300T from 1968" which I have been working on from March 11 to June 27 this year, for about 14 weeks. And I have to say very happy, although I have not yet managed to find a good solution on the BoR link. Have been in contact with the Doxa factory via an acquaintance who is AD in Sweden, so let's see what gets there. But anyway, here's the story: Bought this on March 11 in miserable condition, see photo 1. It was pretty messed up after been worn after 50 years of use as a professional dive watch, so all of the marks were gone on the bezel ring, the glass was scratched, really needed a service, see photo 2 and 3. Some had also tried to change the casetube and crown without knowing how to do this. And should rather been doing things they fully master insted. The casetube was inserted with an wrong angel into the case, so the result was that the crown did not enter the movment right. See photo 4. To fix this, the old casetube had to be drilled out / pulled out. This one was not fastend good enought, so I could just pulled it out. If this is done right, they is stuck like hell. .. See photo 4. you can see the red line that shows the correct angle into the case, while the casetube that was mounted befor was incorrectly angeled into the case, see the blue line. A incorrect crown was also inserted, the original crown is 6.92 mm in diameter and 4.60 mm high, stem thread is 0.9 mm. The one sitting here was far too small and is completely wrong compared to the original. The dial was very spotty and had lots of marks after many dives. And that the lume had got the greyish color. See photo 5. So full dismantling was needed, stripping everything, movment out, glass out, bezel ring dismantled from the case, cleaning of all parts. So when everything was cleaned up, the build-up could begin. First the old case tube had to be drilled and pulled out, so it was dismantled, and the new casetube was inserted with a crown. See photo 6. Found a crown that is quite similar in appearance and about the same size. Doxa is known to have very little parts to these olde watch available unfortunately. So finding original casetube with crown seems like a pretty impossible task. See photo 6. Did service work on the movment, ETA 2783, no parts had to be replaced, just a little tightening of canon pinion, because it was a little loose in motion. Painted bezel ring by original colors. See photo 7. When it comes to the dial, I wanted a crisp and fresh dial, so I chose to use an friend of mine who is an specialist in restoring dials, and who is the real magician when it comes to repaint of dials. See for yourself....See photo 8. Lumes on the hands and indexes was put on by me, had to mix ut a certain light cream color lume to match ut the right patina. Also managed to source a glass made according to original spec. which was fitted. Then after about 3 months, all parts were mounted in place, the work was installed, the test round was done with brilliant results. And I could finally take this piece of jewelry on my arm ... See photo 9. Beautiful!!! Go...Go....Switzerland !!!
  3. Cheers Mates. Look what I found!! An Doxa 300T Searambler from 1963, the year I was born. But this beauty have been heavily used over many years...so she need a little TLC.... So Im looking for some parts: casetube, stem and crown, glas, and glas gasket Someone the have some idee where to start the search?? As alway Im very glad for all the help that I get here !!! Thanks :-)
