Showing results for tags '79320'.
    • Resources and Articles
Found 1 result
  1. Hi, one of my favorite watches is my IWC Flieger Chronograph (Ref 3777). The only thing that annoyed me was, that it was almost 3s late every day. 15s or more in a week! I know, this is complaining on the highest possible level. But still. If she would go 15s fast a week. Fine. But not late. My Weishi Timegrapher 1900 showed it pretty clear. After quite some experience with movements I dared to open it! No way to take the movement out, just opening it. Wow, what a nice movement! But regulating the balance proved to be a challenge: There is a little screw (going from the left to the right) which is used for fine regulation. The only problem: the screw is obscured by the case. And the stud is extremely smooth moving. The first thing I did was bringing the balance out of center while pushing just a little bit too hard. I was totally relaxed, because it was easy to bring it back in the right position with the Timegrapher. What is good about the 1900 model is that the two lines (tick and tack) are in different colors. When you push too hard the yellow line is above the green one (or vice versa) and you know, you went too far. The beat error itself does not change (e.g. turning negative). Very nice and helpful feature. It took me quite a while to get everything in perfect condition. With dial down I had to regulate her 2s fast. To make a long story short: in the morning she is spot on and in the evening she is 1s late (again!). But with crown down she is running 1s fast in 7h during the night. Spot on next morning! BUT: Here is my question: The beat error is 0ms dial down but 3ms dial up. I have absolutely no explanation for that. I thought that the beat error should be the same no matter what position the watch is in. This was also the case before I regulated her. I am looking forward to hear your explanation! Thank you and Cheers Alexander
