Crown Help
Pablo
Hello, the crown on my inexpensive mechanical watch no longer adjusts the hands or date, I have attached 2 photos of the inside
I have tried removing and the crown and replacing sometimes the Crown will suddenly catch as you turn it clockwise
and move the hands slightly but that is all any advice much appreciated
pablo
post-1962-0-22563800-1458740730_thumb.jp
It looks like a Chinese clone to me. Most likely you need to check the keyless works for parts out of place, broken or worn...and btw, Welcome aboard!
Tell us about your experience working with watches so I can be more accurate.
Cheers,
Bob
Hi Bob no experience of working with watches, was hoping to find a video on youtube and came across Daves forum,
have always enjoyed tinkering with things over the years and have plenty of patience and small precision tools.
Took it to a place here in Liverpool told it would have to be sent away and no guarantees. Watch belonged to a relative sentimental value.
I believe it is a chineese clone. Worked fine until young relative wound it up.still keeps time, but cant change the hands or date, crown just turns.
many thanks for the reply
Pablo
In that case, Pablo, you need to know that you have to take the movement out of the case, remove the hands and the dial and check (maybe even remove everything in your way for the check, date rings and stuff like that). Then you will have an idea of what is not engaging when the crown is pulled into hour changing mode. Be careful since everything you are touching is bound to be scratched and is delicate. Even though the balance wheel and its hairspring is on the side you will not be working with it may get damaged if the movement is handled improperly (I would remove it, first the rotating weight and then the balance assembly, carefully). In the end, it all boils down to put everything back together...there is a tick for you to do! :)
In my mind, it is better to send so someone with experience in watchmaking.
Cheers,
Bob
    • Hi,   My name is Simeon I am based in Sydney, Australia and have recently got into watch repair / watch making.  I am very much a learner having serviced multiple forgotten watches, some of which were actually successful!   I have a slowly growing collection of watches, mainly old Soviet, a few Japanese and (not pictured) some Raketas, a Poljot Alarm, an Omega Speedmaster Reduced and a vintage (1972) Tissot Seastar.  I like unloved vintage watches, with quirky faces and enjoy bringing them back to life through the simple(!) act of disassembly, clearing and reassembly. I am an Electrical Engineer who also undertook a trade apprenticeship so I am reasonably handy - It's fair to say, I know just enough to get myself in trouble.
    • ha ha looks like a WMD.....you know I want one now
    • I took a chance on a non running Cosmotron X8 ("perhaps just needs a new battery" said the advert). Sure enough, I open it up and it has the wrong battery installed (a Renata 344 rather than the correct Renata 386) and the screws holding the battery contact had been sheared off to half a head on both ends. Ho ho, I thought - there's the problem. I got the broken screws out easily enough and as soon as I placed the correct battery in place the balance started. This picked up speed when I reinstalled one side of the battery contact and looked like it was a runner. As I was trying to get the replacement screws in, I did one side but the second was a bit of struggle (hold down the battery contact against its spring while dropping the screw in with tweezers) the balance stopped again. This time it wouldn't start again. 98 percent sure that I didn't stick anything, anywhere important or break it in a mechanical way. The battery was in place for most of the struggling with the contact, so it might have had an intermittent connection which could have upset the electronics. I tried giving it a puff with the blower but the balance doesn't seem to rotate in the normal way, it seems to be held in a static position by magnet. It can be pulled out of this position but spins back and stops dead. This may well be correct for all I know. Anyway, does anyone know anything about these watches and can tell me how I would go about and fault find this? I will be servicing it at some point so should be able to rule out mechanical issues from an old watch but not sure where to start with the electrical part of it.
    • Sorry to reopen a necro-thread (long dormant) - I have a Seiko Kinetic 5M42A that needs at least one coil, possibly both. Anyone know of any sources?  The usual fallback of eBay has failed me - there are people selling coils, but not the ones for this movement (which was apparently a very popular movement, used in Seiko and Pulsa branded watches.) The coil numbers are: 4002 516,  and 4002 519 I'd also love to find a source for spares of the screws used all over this movement - they're Seiko PN 0022 247 Thanks! (Moderator - if this should be a new thread, please do feel free to tell me, or drag this one into a new thread.) Don Eilenberger
