Crown Help
Pablo
Hello, the crown on my inexpensive mechanical watch no longer adjusts the hands or date, I have attached 2 photos of the inside
I have tried removing and the crown and replacing sometimes the Crown will suddenly catch as you turn it clockwise
and move the hands slightly but that is all any advice much appreciated
pablo
post-1962-0-22563800-1458740730_thumb.jp
It looks like a Chinese clone to me. Most likely you need to check the keyless works for parts out of place, broken or worn...and btw, Welcome aboard!
Tell us about your experience working with watches so I can be more accurate.
Cheers,
Bob
Hi Bob no experience of working with watches, was hoping to find a video on youtube and came across Daves forum,
have always enjoyed tinkering with things over the years and have plenty of patience and small precision tools.
Took it to a place here in Liverpool told it would have to be sent away and no guarantees. Watch belonged to a relative sentimental value.
I believe it is a chineese clone. Worked fine until young relative wound it up.still keeps time, but cant change the hands or date, crown just turns.
many thanks for the reply
Pablo
In that case, Pablo, you need to know that you have to take the movement out of the case, remove the hands and the dial and check (maybe even remove everything in your way for the check, date rings and stuff like that). Then you will have an idea of what is not engaging when the crown is pulled into hour changing mode. Be careful since everything you are touching is bound to be scratched and is delicate. Even though the balance wheel and its hairspring is on the side you will not be working with it may get damaged if the movement is handled improperly (I would remove it, first the rotating weight and then the balance assembly, carefully). In the end, it all boils down to put everything back together...there is a tick for you to do! :)
In my mind, it is better to send so someone with experience in watchmaking.
Cheers,
Bob
    • The entry and exit stones have different impulse face angles  murks.
    • Depending on how much of the screw is left, you may be able to screw it further in and it may fall out of the hole that the dial foot sat in. To do this I rough up the tip of the good screw and screw it in, often the rough surface of the good screw and the rough surface on the broken screw get enough of a bite to transmit the torque into the broken section and force it out the other side. Like I said the size of the broken screw needs to be in your favor, but you never know you may get lucky.... or if you get it moving you may be able to then back it out with a screwdriver taking a bite on the rough surface. worth a try
    • I will try this weekend.  I've tried several times with my cell phone and it's just too small and recessed to get a good picture.  I need to get my macro lens and tripod out and then figure out how to get enough light down the hole in the side of the man plate to  actually show the top of the broken screw. I appreciate the effort and will try and get that pic this weekend.
    • Hi,   My name is Simeon I am based in Sydney, Australia and have recently got into watch repair / watch making.  I am very much a learner having serviced multiple forgotten watches, some of which were actually successful!   I have a slowly growing collection of watches, mainly old Soviet, a few Japanese and (not pictured) some Raketas, a Poljot Alarm, an Omega Speedmaster Reduced and a vintage (1972) Tissot Seastar.  I like unloved vintage watches, with quirky faces and enjoy bringing them back to life through the simple(!) act of disassembly, clearing and reassembly. I am an Electrical Engineer who also undertook a trade apprenticeship so I am reasonably handy - It's fair to say, I know just enough to get myself in trouble.
