Reusing mainsprings in an automatic and slipping
You mean you've lost the rotor bearing as it's all one piece? Photos would help.
It's a spare from another watch. It's 0.5mm Dia. spring steel if you want to make one.
Thanks Andy, much appreciated. Was that one you made or pulled from another watch? Assuming it's one you made what's the diameter of the wire? Thanks once again.
By SwissSeiko · Posted
I use an old oiler that is bent to a similar shape. I also just go in through the spring while its attached to the cock still. wristwatches can be tricky
