I am planning on making some homemade Etachron tools from brass rod.  This will be flattened and formed into a a flat crescent, with a slot filed into it that will act as a wrench for turning studs. Would steel be better? I could use pieces of old mainspring that I have annealed to allow them to be filed to shape.
Does anyone know the dimensions of the studs?  Are they all the same? I know that there are differences between Seiko and ETA.  I only have one watch on hand with Etachron (an ETA based movement), I can measure this but I don't know if that would do for all ETA based Etachron.
    • How would it bend like that? Maybe an inexperienced tinkerer tried to remove the weight by levering it up... I'd keep an eye out for other problems in this one, especially bent or broken train wheel/balance pivots. By the way, since we're all learning here, you could have a go at fixing this one! Maybe some careful whacks taps on a staking set (if you have one) would do it. Worst case, you still have a broken rotor. No idea, I've never tried to repair this kind of damage. Of course, get the replacement if you want, but don't pass up on a learning experience.
    • Thanks again for your help.  I have cleaned everything, apart from the mainsprings and barrels, and it's all nice and shiny.  I have cleaned the holes with dry peg wood sticks.  I haven't oiled anything yet.  I have temporarily reassembled the going train and am very pleased to say that for the past 2 hours it has been ticking nicely.  The replacement hourwheel which I referred to in my original post fits very loosely but nonetheless seems to engage and travel round perfectly well.  So now I need to reassemble the strike train.  Is there a set of diagrams which I can refer to for this?  The strike wheels have dots marked on them which must be designed to help but I don't know which one aligns with which.
    • I filed a Seiko regulator wrench out of a screwdriver.
    • It's a so-called split stem. I'm guessing the spring is for the screw-down crown operation. I don't think I've ever seen both features together before, but it looks complete. If I'm right, the crown will have an inner thread and the tube a matching external thread. Replace the seals if you want it to be watertight. If you can compress the spring far enough, slide the two parts of the stem together sideways. If that doesn't work, you should be able to push them back together end to end, the opposite of how you pulled them apart.
    • I have purchased some lume to redo the hands. Luckily I have another watch with the incorrect hands lume that I can practice on first. The colour change is also matching the same colour so I can use these hands to validate the colour is correct before I remove the lume from the Omega hands. I purchased from Nocti Lumina after seeing Marshall use them on WWR and they were great. Not only did they help me pick the perfect colour but they also very kindly gave me some different coloured lume so I can tweak the colour I have if I need, but they are confident the standard colouris going to do the job.
