Hello everyone,
I recently encountered an issue while working on my Seiko 4006 movement and could really use some advice from those with experience in watchmaking.
I purchased a new mainspring from Cousins GR2378X and attempted to install it straight into the barrel without success. Subsequently, I used my Bergeon NO7 Left hand winder and managed to successfully place the mainspring into the barrel.
As the original barrel arbor was missing, I had already ordered a replacement from Cousins (part number 213805). However, I’m now facing a problem: when I insert the new arbor into the mainspring, I can’t get the barrel lid to close—it simply won’t fit.
I've taken several photos to illustrate the issue, which I will share for better clarity.
I know I must be doing something wrong, but I’m not sure where. I’d really appreciate it if someone with experience could shed some light on what might be going wrong.
Thanks in advance for your help!
Best regards,
TT
Thanks for the reply!
The problem is that the barrel arbor doesn’t stay centered inside the mainspring. When I insert it, it feels like it doesn’t catch properly, and as a result, it sits off-centre. Also, on the other side of the barrel, the arbor’s pivot doesn't protrude far enough—it should stick out long enough to engage and keep the full barrel assembly stable, but it doesn’t.
You can see this clearly in the photo.
Thanks for pointing out the raised section of the mainspring between 9 and 12 o’clock—I hadn’t noticed that earlier. I might be able to sort that out, but I’m not sure it’s the cause of the problem I’m facing with the arbor fitment.
Appreciate any further suggestions!
Thanks again,
TT
I ordered the Seiko 213.805 barrel arbor from Cousins. They don’t have a photo on their website, but the part number is SEI213805 if you’d like to check it. It’s described as “Seiko 213.805 Barrel Arbor.” However, if this is supposed to be the correct arbor for the 4006, the one I received is completely different.
Apparently this the case.
Thanks
Update on Seiko 4006 Barrel Arbor Issue
Just a quick update for those who kindly offered their help—thank you again!
I’ve now confirmed that the issue was due to an incorrect barrel arbor. I ordered the Seiko 213.805 barrel arbor from Cousins (part number SEI213805), which was listed as compatible, but after comparing it closely and contacting Cousins, they confirmed that the part was not correct for the Seiko 4006. It turns out the wrong item had been listed or picked.
That explains why the arbor didn’t seat properly or extend far enough to hold the barrel assembly securely.
I appreciate everyone’s input—it really helped me think through the problem more clearly.
Thanks again for your support!
TT
    • So you apply the Fixodrop after oiling? How do you apply it? Thanks.
    • That worked perfectly. Thanks AndyGSi
    • I wouldn't say it's super easy. A correct size mainspring winder is needed and leaving the T end out of the winder is the trick to get it in. Not the easiest thing for a newbie.
    • Apparently this the case.  Thanks  Update on Seiko 4006 Barrel Arbor Issue Just a quick update for those who kindly offered their help—thank you again! I’ve now confirmed that the issue was due to an incorrect barrel arbor. I ordered the Seiko 213.805 barrel arbor from Cousins (part number SEI213805), which was listed as compatible, but after comparing it closely and contacting Cousins, they confirmed that the part was not correct for the Seiko 4006. It turns out the wrong item had been listed or picked. That explains why the arbor didn’t seat properly or extend far enough to hold the barrel assembly securely. I appreciate everyone’s input—it really helped me think through the problem more clearly. Thanks again for your support! TT
    • Had another strange one on my bench. A Titan ladies watch with an unknown movement. It had a battery leak and initial test revealed a short circuit. I removed the PCB and gave it an acid wash. The short was cleared and I reassembled the movement and dropped in a new battery. I thought that was it, job done. But when I looked at the second hand carefully, I noticed something wasn't right. It would tick one second, then twitch the next second. Like ... tick ... twitch ... tick ... twitch. Weird! So I disassembled everything and ran it through a cleaning cycle. I didn't take any photos during disassembly because I thought "how hard could it get? It a quartz watch". Boy was I wrong. Took me 2 hours to figure out where everything went. But everything worked out fine in the end.  After dinner, I researched more on the Titan watch company and found out that the movement is an in-house movement, the 5130. There was a video on YouTube even.
