I have an early Bulova wristwatch that I hope to be able to get going. It was an eBay purchase which I bought out of historical interest. I'm interested in Bulova watches principally because the first watch I successfully repaired was a Bulova that I'd bought for myself.
s-l1600.thumb.jpg.dd430dca5c6f83f8b5324af072619ecf.jpgs-l1600-3.thumb.jpg.52583a617f86a18f0101be48022ab45e.jpg
The watch offers me a number of challenges, some of which I think I'm ready for; others not so much.
When I first opened the watch I noticed two things immediately: there was oil everywhere, and the balance wheel looked bent.
Ok, I'll remove the balance from the cock and then disassemble the movement and clean it while I see what can be done with the balance. First challenge: there is no screw for the stud. How to remove it? I've already had some assistance with that in this thread. Opinions were divided whether to push the stud out or unpin the spring from the stud. I pushed it out. (There's also some information in that thread about my fruitless attempts to put a number or code to the caliber.)
I took a square-on photo of the balance so I could superimpose a circle to see just where it began to be out of round, then cautiously began to manipulate it, gently pulling up the side that had been bent it. As soon as it came clear of the point where the two ends crossed (in the right of the photo above), the balance sprang back into shape. I'd been catastrophising that I'd struggle to get it in anything like good poise but now it looked like it might be already there. Phew.
The hairspring will need a little adjustment ... it looks to have been a little bent at the regulator, but I think I can deal with that later.
Next, attempting to let down the mainspring gave some difficulty. Initially the crown would not turn at all, then I realised it was in the hand setting position. Why that resisted the crown turning is an issue for later. Pushing it in to winding position allowed it to move a little, but it seems the mainspring was fully wound and I could not move the ratchet wheel enough to release the click. In the end I removed the pallet while holding the train wheels so they could not unwind catastrophically. I wasn't too worried, as I'd already determined that there was little to no power coming through to the pallet. Even with it removed it was only by working wheels forward and backward that I could unwind the mainspring enough to be able to release the click and unwind the rest of the spring through the crown. Removing the train bridge revealed an oily clump of fibres caught in the train.
Inspecting the pallet revealed a lack of shellac on one side. I discussed that a little in this thread. The jewel on that side is not quite straight.
It also looks like the guard pin is bent, but I don't think that's actually a problem. When I inspected it under my stereo microscope I found the pin parallel to the horns of the fork in the vertical plane, as it should be, and the top of the pin centred between the horns of the fork. I believe it looks bent because the base of the pin is off-centre but as it's the tip of the pin that is important I don't think that matters.
The next challenge, and probably the greatest one, was encountered when disassembling and inspecting the jewels. First I noticed the pallet jewel:
Ugh. I'd love to be able to clean that up, but the chance of my doing so successfully without damaging the jewel? Not worth it just for the aesthetics of it. I checked that the pallet sits properly in the jewel and although end-shake is a little high it seems it's probably going to be acceptable.
But then I saw the escape wheel lower jewel:
The rest of the jewel came out in the ultrasonic and seems to have vanished, and in the process it seems to have slightly damaged the feathered edge for the rubbed in setting. This leaves me stumped. I don't have the tools to open and re-burnish a rubbed-in jewel, and I can't find where to get them. I can make a tool to open the setting, I think, but closing it again will be more challenging. Even if I had the tools, however, where can I get the jewel to go in there? From what I've read, rubbed in jewels have a different shape from friction fit jewels.
It seems to me that it may be more productive to replace the rubbed-in setting with a friction fit jewel. I'm not worried about it making the movement less original (especially given that it'll be hidden away on the dial side), but I'm not sure how to go about it, either. Some of my reading suggests that it might need a bushing made. I don't have a lathe, and any such acquisition is likely over the horizon for me, so if that's what's going to be needed then I'll have to do the bits I can then shelve the project for now.
While meditating on the escape jewel I thought I'd just check how the balance sits between plate and cock: not well. After a first attempt where the pivot kept coming out of the jewel as I was trying to fasten the cock I tried the cock by itself, and it does not sit parallel to the plate but rises at the end. Trying again with the balance wheel I confirmed that the balance end shake is so great that the pivots can come right out of their jewels. The cock is bent and will need to be bent back into place. Another thing I'm not sure how to do. I presume I shouldn't just hit it with a hammer.
First focus on escape wheel jewel.
First take a look at this video
Of course, everything is possible without special tools here. But yes, replacing the setting for bushing with press-fit jewel is possible and is good option too. I will need better photo of the jewel hole now, as what I sow in the other thread is little bit frightening as the hole may be ruined already.
Lol hitting with a hammer is the final emotion when nothing else works...even that isn't acceptable,because...well everything in watchmaking is useful...eventually 😁. The most difficult job first which is the escapewheel jewel. If that cant be accomplished then all the other work is just an exercise.
It won't surprise me if the hole is already ruined, and it may not be all my doing. All the jewel settings on the plate have been crudely countersunk.
Balance jewel: QuickCameraImage2024-12-30at9_00_24AM.png.546b928b0eb2bf123925880f8769510a.png
Pallet jewel is the most obvious: QuickCameraImage2024-12-30at9_00_48AM.png.e7aeab458d4a9078bc31687b3f90ba5b.png
Escape wheel where the jewel is missing still shows signs of having been countersunk which is why it's so thin and out of round at the edge: QuickCameraImage2024-12-30at9_01_09AM.png.1c87316bda8f40009e079f02100a71df.png
Fourth wheel: QuickCameraImage2024-12-30at9_01_24AM.png.9ba84b9fc0d6fa820ac1ae6d47130313.png
Third wheel: QuickCameraImage2024-12-30at9_01_35AM.png.ea44e1d3bb6aa62a2a18f3fdb461fce6.png
There's also some butchery presumably to create adjustable banking pins:
QuickCameraImage2024-12-30at9_19_17AM.png.26a295f80de0c1868ae7157e906b1709.pngQuickCameraImage2024-12-30at9_20_29AM.png.442ed4de1646ec0b59d46e423eef1ac7.pngQuickCameraImage2024-12-30at9_21_19AM.png.99f8e9d3bb14f0e9d0340499d524e452.png
Clearly someone has put quite a lot of work into this plate. I wish I could be confident they knew what they were doing.
The dial side of the plate looks untouched:
The balance jewel is red so likely not original. Is it still rubbed in or has a friction fit jewel been used? I can't tell. QuickCameraImage2024-12-30at9_02_51AM.png.23eacf2228a4be2e7964833bd9fa25ec.png
The pallet jewel: QuickCameraImage2024-12-30at9_03_39AM.png.3023b2cbd8a4637ea38d0082a795031e.png
What remains of the escape wheel hole. The feathered edge is somewhat chewed up. It looked ok before it went into the ultrasonic but when I came to try to open it up it already had cracks.QuickCameraImage2024-12-30at9_04_26AM.png.d8e5c4a1f39e07655c3bf76db3cd1e78.pngQuickCameraImage2024-12-30at9_04_52AM.png.9e655dd2fca2592d4a66376ab1b718aa.png
Fourth wheel: QuickCameraImage2024-12-30at9_05_47AM.png.7f3ac72b6fb07c1f7ba70112075ab0dd.png
Third wheel:QuickCameraImage2024-12-30at9_06_04AM.png.208e75feb94a81eaf64c44864fa2de93.png
@nevenbekriev, I loved the video: very helpful. However all the donor movement parts I have use friction fit jewels so I don't have anything I can harvest a suitable jewel from.
Side note: I don't have ANY spare jewels. Cousins do a jewel assortment of 1000 hole and cap jewels for £9.95. What are opinions on that? Is that likely to be useful, or will I just have 1000 jewels all the wrong size whenever I need one?
Such a lot of countersinking to all the jewels, very strange. I'm thinking a lot of these jewel settings are pressed in and some are rubbed-in jewel settings. As regards to the 1000 cousins jewels, I bought the same vial of jewel off Ebay. About half of it was rubble and bits of metal, discarded,defective and damaged jewels. I sorted all the ok stuff, measured it up and added it to stock. If you use just one jewel from it, you will just about break even.
I think its basically just floor sweepings.
Modern friction fit jewels can be used as rubbed in, but some preparation of the jewel is needed. At least one of the edges needs to be rounded as to allow the collar to lay and fix the jewel. For this purpose, the jewel must be glued on the face of thin rod (thin as the jewel OD). Then the edge is to be ground on diamond disk or plate while the rod is rotated by hand.
The hole for the jewel seems still usable
Thanks, I'll have to experiment.
  • 4 months later...
This poor watch now has a new escape wheel jewel. I got a jewel assortment and found one that fitted snugly in the setting, and whose hole was a neat fit on the escape wheel pivot, glued it to the flattened end of a 1mm drill bit and turned it on some brass with diamond lapping paste to give it a taper on one side. I used a sewing needle to gently close the setting over the jewel. It doesn't look too bad in the pic, but actually about the bottom third of the setting has nothing left holding the jewel down and I'm not sure whether it will hold. I'll have to see when I reassemble it.
Before I reassemble, I thought I'd better have a look at the balance and check its poise. I put it on a pair of tweezers and found it did indeed want to always stop with the same point uppermost, swinging to and fro around that point. While I was thinking about timing washers and that I don't have the right tool to remove a timing screw, I noticed that one of the pivots didn't look straight. A closer look was called for:
The right hand (upper) pivot is definitely bent.
So, should I try to straighten it? It is likely to break, I suspect. Am I going to be able to buy a replacement balance staff for a watch more than 100 years old with no movement number? Seems unlikely. I have no lathe so I'm not in a position to make one myself. What are my options?
What size is the movement and have you done the usual search with bestfit.
To me it looks like something in the 10 series.
The other option would be to measure the staff and try and trace it from their, or at least find an equivalent.
Edit
Just realised after a bit more digging the manufacturer is marked on the movement 'FREY'
Edited by AndyGSi
I measure the movement as 23.42mm diameter. I guess that'd be called 10.5'''.
I don't currently have access to bestfit.
I believe this watch is from 1920 or 1921. That predates Bulova's stamping of a symbol to represent year of manufacture and may predate their systematic movement codes. In any case, there is no movement number stamped on it.
It was based on a Frey ebauche, but so far knowing that hasn't helped me.
So based on the 10.5 would make me think a Frey A but could also be one of these if you can measure the staff.
These are all the Freco Ronda Staffs so expect it's a 1 1086, 1087 or 1088
Edited by AndyGSi
I measure staff length as 3.42mm. Assuming that's the last column, I guess I have a 1088. Will it really be as simple as ordering that part from Cousins? I'm thrilled if so, although it's not cheap once I factor in postage to AU.
I'm sure it's the ancien.
My measurements:
A = 342. The slight bend in the pivot would make much less than a thousandth of a mm difference to this so I don't think 348 is plausible unless there has been significant wear on the pivots.
B is hard to measure without first removing the balance wheel. I measured to the other side of the balance wheel as best I could (263) then subtracted the thickness of the wheel (69) to get 194. This could easily be three or four hundredths out, so 195 looks right. (196 could also be right.)
J couldn't be measured. I did my best to measure where the balance wheel has been riveted on and got about 95, so 85 before riveting is plausible. (60 is not.)
G again couldn't be measured without first removing the roller. I get 37 where the staff emerges from the roller so 41 at the other end of the taper seems plausible. (43 is also plausible to me.)
K = 60. (Definitely larger than 55.)
I've never replaced a balance staff; it'll be a new adventure for me. I'll have to read up on how to maximise my chance of removing the old one without damaging the balance wheel without having access to a lathe. I also need to explore how to remove the roller without damaging it.
I won't actually place an order until I've gone through the rest of the movement. With the number of issues I've already found, I'll be amazed if I don't have more surprises in store.
There are some watch part suppliers in Australia but nothing like Cousins or Otto Frei or Jules Borel. AllTimeCo is fine for basic parts for modern watches: batteries, bands, some crowns, stems, seals, movements, some tools, etc., but not really anything for vintage watches. Australian Jewellers Supplies is similar. Cousins charges about £9 for shipping to Australia which is about AU$19 and not too bad (considering Australian parcel post is $11) but I still want to minimise the number of times I'm paying it.
I need to explore other options closer to home. There may be something in Singapore or China that would have what I want and ship it faster/more economically.
This watch has a pin end mainspring.
QuickCameraImage2025-05-13at8_51_36am.png.b7b4790e1b0a5d41835c2634d5c9dc21.pngQuickCameraImage2025-05-13at8_56_39am.png.501569eda29b9f96572ee7683af2ecac.pngimage.png.30e730f7ac5093413aef4e6ff7358224.png
It's a blued steel spring and may be the original >100 year old part. As you can see, it is quite set. Can anyone suggest where I might be able to obtain such a spring today?
Dimensions:
Height: 140
Thickness: 010
Arbor diameter: 340
Barrel diameter 989
(1/100 mm)
Hmm ... I can't find anything with a pin like this. I guess with a lathe I could make the pin, then drill a hole in a regular mainspring and rivet the pin to it. Can't really see me doing that without a watchmaker's lathe, though. Am I going to have to shelve the watch because I can't replace the mainspring? There has to be another way.
I wonder if I could cut off the end of the existing spring and use it as a catch for a modern manual-wind spring to hook on to?
Edited by GPrideaux
Afterthought
Can you not remove the pin from the existing spring and just use that?
I think if you did something like this you'd need to make sure the piece you cut off was
long enough so the thickness didn't interfere with the stud staying in the hole.
The stud has a neck that is a little smaller in diameter than the end and the hole is keyhole shaped so the stud locks in and I wouldn't need to worry about the thickness of the tail pulling it out of the hole.
It might be possible to remove the stud from the existing spring, but I don't know how I'd go about doing that in such a way that it would be reusable. Maybe work around it squeezing with pliers until the riveted end became small enough to pass through the spring?
A few more higher magnification pics of the pin/stud:
QuickCameraImage2025-05-13at7_21_53pm.png.40cca9bd79a5c9c3a4d5ee6197297b01.pngQuickCameraImage2025-05-13at7_20_39pm.png.9cc8029a8903fa34d289efb5002d310b.pngQuickCameraImage2025-05-13at7_22_40pm.png.d4ab1b23020ffbcc80a07b3d8ec87b6a.pngQuickCameraImage2025-05-13at7_23_58pm.png.73d67262ed06f9d1d7509e8ccadd60dc.png
Sorry for the confusion but I was referring to the stud staying in the hole in the barrel.
Yes, that's what I mean, too. The hole in the barrel is keyhole shaped and once the tapered end of the stud is inserted and slid into position it is quite secure and can't pull out. It was quite difficult to remove as I had to slide it along the hole to the larger end before it would come out.
Glen, I've only just seen this, if you haven't already , lets have a go at identifying this movement.  I have a few different catalogs that often successfully match keyless works parts.
But you'll need to make sure the end of the old spring with the stud
is long enough to enable you to bend the new spring over it.
Movement is already sorted as a Frey/Freco Ancien
It's not actually that bad Glen. If the movement is in good order otherwise, I see no reason not to re-use this.
What is the comparable barrel to unwound mainspring diameter?  X3  ?  X4 ?
    • I've been trying to create a dial hip screw, and I'm running into an issue when threading the screw with an M0.7 thread.  I can create the rough form of the screw from O1 steel with little issue, but creating the thread is where things can go wrong really quickly.  I am using a thread plate, and I've seen tutorials which say to hold the thread plate square against the screw by using the tailstock as a brace.  I use tapping fluid, apply gentle pressure to the tailstock lever and I'm very generous with regards to advancing the headstock to cut the thread, and then backing off to help break chips.  But each time I get nearer to the base of the screw near the head, I end up shearing the screw off completely from the rest of the body.  With a screw that small, you have almost no feedback from the screw if you're going too hard, which ends up breaking the screw.  I turn the screw shank to be a little longer than the width of the die plate, so that there's something to grab with a pin vice if it breaks off.  What can I do to better my chances of success?
    • Evening, I've been staring at this for far too long and my web searching has been fruitless, though interesting in respect of other watches. I can't be the only one with this issue. This is my sons Timex, he likes it a lot though somehow managed to knock the bezel off. Doesn't know how and lost the bezel for some time. Luckily he found it again!           My first foray into case issues and I'm learning. Now I'm guess the missing piece is a spring? Would anyone know what shape/size it is? I'm looking to perhaps fashion a replacement or source something similar. I've tried the dental floss trick to hold it on, making it bi-directional. It works to a fashion but doesn't fill me with confidence. I'd really like to give it, it's click back.  In terms of tightening it (last picture) I guess by bending the wavy wire to make it grip better or would the ratchet spring be/should be sufficient to hold it in place? Thanks in advance
    • I have the exact same dilemma struggling to remove the Stem. Did you get this sorted? How did you do it?
    • Hi i was wondering if you had looked at the photos of the watch. Do you know what it is. Obviously it’s very old. But as to the maker I have no clue  thanks. 🙏
    • John, the plate (actually the barrel bridge) is not worn or at least this is not the problem. The big washer (which is also part of the crown wheel bearing) under the crown wheel screw in You movement is missing. If You put it as should be, then the movement will wind normally. But, as the crown wheel is now a little worn on the bottom side, You may have to put it upside down. A little ugly, but this is USSR movement
