Outside diameter of modern Bergeon Seitz reamer spindle?
Can anyone report the outside diameter of the modern Bergeon Seitz reamer holder spindle? According to Cousins, the modern reamer shanks are 2.35mm and I am wondering if the new spindles are about 7.95mm like the older ones or if those have changed
Very inexpensively, I acquired a C&E Marshall jeweling press with its weird reamer sizes (like 1.51mm instead of 1.49mm). Since I know this will be mostly incompatible with the more readily available seitz jewels I'll probably pick up seitz reamers as needed. The old Marshall reamer spindle is about 7.9mm and reamer shanks are 3mm.
So if modern Seitz reamers are indeed 2.35mm rather than 3mm as the old ones seem to be, I'll need a new spindle. If someone can confirm the new Seitz spindle is somewhere just under 8mm I expect I can use it with the Marshall tool.
Thats a bugger mate. I've got all 3 , old and modern seitz and the C&E. Indeed the reamers are smaller for the C&E which is why i got the 2 seitz. They also have no relief ground on the backside of them like the seitz reamers. Spindles are about 3-4/100 out,  CE spindle is 7.94-5 ish and both Seitz are 7.98. The seitz spindle wont push through the C&E frame. You might be able to dress one down, it will go about half inch then gets real tight sorry.
Actually the C&E reamers are bigger than the seitz, the spindle is definitely smaller. Just tried my Star spindle as well , bloody thing is stuck in the frame 😅
What's the diameter of the reamer shanks on your 2 Seitz kits? I see a lot of them available on ebay with purported 3mm shanks (which I could use), but Cousins says the contemporary ones are 2.35mm.
They are tapered 2.5- 2.35
The Marshall spindle utilises a collet to hold the reamers i think ( i dont use it much ) rather than tapered reamers and a hole for a release key. Might you be able to fashion something up to take the seitz reamers. I'll have a look after I've had a cuppa.
Still more variation. My Marshall set is probably older than yours, with a cast iron frame. The reamer spindle does not have a collet and the friction fit reamers are tapered apparently 2.80mm-3.10mm. Ultimately, if all I need is a rod 7.90mm in diameter with a 3.00mm hole at one end, I can probably find a way to acquire that though I don't have a lathe.
    • Since I couldn't slow the machine down enough for my liking, I started off slowly with a higher grit.  I began (very lightly) with 1000 grit paper: https://www.amazon.com/gp/product/B07DTJBND1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Finished with 3000 grit: https://www.amazon.com/gp/product/B07DTFSMT1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Afterwards I went on to polish with traditional methods using felt & cotton wheels, with different grades of Dialux. Hope this helps.
    • Ok so there is barely any response happening . After this last attempt i think I'm just going to give up on it because very few seem genuinely interested or even bothered or worried what may happen in the future. ( if someone can set me straight I'd love to hear it ) I would think anyone into watches has heard of Roland Ranfft, how they grew to love and depend upon his site for detailed information. And not just that, he also had a view about Ebay and everyone that visited Roland's site knew exactly what he thought about Ebay, Roland's site also had a secondhand watch sale side to it.  If anyone here could have done anything to preserve his site and keep it exactly the way it was.........Would you have done something to make that happen ?  Its been pointed out to me but not in so many words  that I'm probably coming across as an insensitive p.rick, truly I'm sorry about that, i say it as it is but no malice is intended and yes clearly I'm putting my forum membership on the line here. I'll happily shut up about it now, I've done all i can.
    • Thank you so much for posting this!  Although this movement is serviceable, there are no service notes that I've been able to find.  This is a great alternative!
    • Greetings from another electronics designer & programmer!   I suggest you get a batch of similar scrap movements from ebay - I found batches of Seikos very cheaply, I got seven of one type for £11 (or 11 Euros possibly?). Those were ladies, 4206B I believe. There are also mens movements at a slightly higher price; eg. https://www.ebay.co.uk/itm/134723051997 https://www.ebay.co.uk/itm/235565276549 They are cheap enough so it does not matter what gets messed up or lost & you can probably still get one or two working movements from a batch, even if some part are damaged when you get them. (I've had quite a bit from the guy in Holland, he usually has a good range of movements).
    • Please OH, we should all be proud of our collections what ever they are. If we can't show them off here then we can't show them anywhere. Our favourite gives us a story to tell of why we love it, that story also tells others something about ourselves. These are some of the things that make our forum and our community so amazing .
