Illinois Hair Spring Screw Too Small
Haha, tell him you're supposed to fill the pool with water before diving.
That could be another sign it's up for some TLC. Perhaps too much, too little, or the wrong type of grease was applied to the barrel walls. Perhaps it occasionally slips too much, which could explain the funny initial timing machine readings. Thanks for the input! On second thought, probably not, as it was doing perfectly 24 hours later... Hmm... Perhaps there is some debris floating inside, getting caught and uncaught between some teeth and pinion leaves!? If there is one thing I’ve truly learned over the years, it’s that you must be extremely meticulous about cleanliness and observant of different types of debris that can end up in the movement, such as dust, skin flakes, clothing fibers, etc.
Thank you Dell! Very useful information for me! I saw your videos and they are great! You do an amazing job! And I saw one where you are using the lathe very slowly and it seems to work perfectly. I will take your advice and go for 3/4 hp motor. The one I saw comes with a nob to select the speed and it has the forward/reverse option with I like. thank you very much again for all your help!
There might be something wrong with the mainspring. I don‘t hear any slipping when I fully wind my 3135.
