Making Bracelet End Links
Are there no obvious notches or indents around the back? Is that just a rubber plug? Normally something like this would be to access the balance for adjustment without removing the back, but it seems in a strange position for that.
I don't think you'll get a response as @CaptCalvin hasn't been on the forum for nearly 3 years. Edit That should have been nearly 4 years.
As you've shown the crown and stem is the winding position. You then need the second hole to be able to push the crown further towards the case to screw it down.
Search 'PCB carbide drill bits'. They come in sets of 10 or 50 and have 3.175mm tail. They are cheap rather than affordable. Using this drill bits has been discussed here many times - they are longer than needed and easy to break, so it is useful to practice sharpening hem and drilling some useless parts to gather some experience before real work. -
I'm a newb who is a bit late to the party here. I've purchased a Horia movement holder clone. And I'm aware that the support pins for the SW500 chronograph jewels can be different sizes. I purchased 0.8mm pins with the holder. These were all that were available at the time. Will these be the right size? Can someone shed a little light on this for me please?
