Showing results for tags 'unitas calibre 6325'.
Found 1 result
  1. Unitas Calibre 6325 Service Walkthrough Pictures - Disassembly (Please sort the pictures by name in ascending order) For the disassembly sequence to make sense it is very important that the pictures are sorted by name in ascending order. Generally, the sequence of pictures first shows the part to be removed in its position on the movement and the following picture shows the removed part separately. Unitas Calibre 6325 Service Walkthrough Pictures - Assembly (Please sort the pictures by name in ascending order) For the assembly sequence to make sense it is very important that the pictures are sorted by name in ascending order. Generally, the sequence of pictures first shows the part to be assembled along with any screws holding it in place. The following picture shows the section of the movement where that part is to be assembled along with my lubrication suggestion, and the picture after that shows the part when assembled on the movement. The Unitas calibre 6325 is very similar to the Unitas calibre 6498 which is the course movement on watchrepairlessons.com. Unfortunately, due to its increasing popularity, the Unitas calibre 6498 is becoming more and more expensive, although there are inexpensive Chinese clones. So, in my opinion, Unitas calibre 6325 is an excellent and inexpensive option for the course. As a matter of fact, there is a version of the Unitas calibre 6325 having a bridge configuration that looks to be identical to the Unitas calibre 6498. You’ll find plenty of watches housing the Unitas calibre 6325 on eBay. Unitas Calibre 6325 links: bidfun-db Archive: Watch Movements: Unitas 6325 - mtr-Ranfft Unitas 6325 - 17jewels.info „Wehrmachtswerk“; Unitas 6325 - Junghans Vintage
