Showing results for tags 'lord matic'.
Found 1 result
  1. Greetings all, I am restoring a Seiko Lord Matic (5206A) and have a question about the automatic works rotor. When I opened up the watch the rotor was very loose and (fortunately) this was due to it not being screwed on very tight and not a bearing problem and I removed it with a few turns using my fingers. However, the thought struck me that I'm unsure how to put it back on, what tool should I use as it is a chunky rectangle and not a slot type where I could use a screwdriver (see picture below - Note: this is a similar movement picture from google as the picture I took of my watch isn't as clear). I don't want to grip and try to tighten it with tweezers as I think the chances of slipping would be high and I probably couldn't apply enough torque this way before damaging my tweezers and/or slipping and scratching up the watch. Anyone have any ideas what tool I can use for this job? Maybe I could 3D print something if there is no easy answer out there?
