Showing results for tags 'favre-leuba'.
Hi Guys.. Just received this Favre-Leuba Datic. It has an FL1188 movement which is basically the (much maligned) AS1687 in drag. While not as unique as the Favre-leuba's in house Cal.253. It has been used in some higher end watches like Girard-Perregaux and Zodiac. Some shun this movement because of its offset canon pinion but generally its not so bad. It's only if you need a replacement parts that it gets messy. The plating on the plates are the same as on the Cal.253 though. At least FL was consistent! Anyway, here it is...dial has 'patina'. IMO patina is overrated but at least its here it's even. The caseback is pretty.. The movement..pretty messy huh? I was reminded of the tea trick on another thread. I will try this when I tear this one down. Nice thing about this movement (and other 1687s) is that it has a geared regulator, allowing better, more precise adjustments. A button, nowadays more commonly known as a crown. Nothing remarkable as it's a generic replacement but I will see if I have a genuine (used) FL one which I can fit. I don't usually pay much attention to the inner case back but something caught my eye. It was only some dirt which came off when I scraped at it with my tweezer. This watch will be getting a service soon as it's pretty dirty inside. There's been several posts about the as1687 so I won't be posting about the rebuild unless I come across something unusual. Anyway here's a picture of the dial side. I think it's one of the better designs from the 50s. The date snaps over instantly . Just like Rolex! And it's nice to see a jeweled barrel arbor! Thanks for reading! Anilv
- 7 replies
- 4
- favre-leuba
- datic
(and 2 more)
Tagged with:
Sharing a vintage Favre-Leuba Daymatic today. I believe it's from the late 50s or early 60s... Date was first included as a window in the dial around this time.. The pioneer was.. Rolex. Up close the dial looks pretty aged but at least it's legible and even across the dial. Case is not overly polished and the edges are still distinct if not sharp. Crown has marking but not FL. And between the lower lugs the number 1944 is engraved. Probably a serial or model number as this watch is not that old I think. The number 1944 is repeated on the case back as well. Perhaps 1944 is the model number and 64003 is the serial number? The case back is nicely done and we can see the hourglass which was later stylized to become the FL trademark. This inside of the case back is only marked with... Vacuum.. An inside is a nicely finished movement.. I think it's a Felsa of some sort. Again we see the hourglass.. Quite a good effort. But what really attracted me to this watch was the band.. It's in really nice condition and fills the lugs nicely without any gap.. Not surprising as its... ...meant for a Favre-Leuba! ..this is a stylized version of the hourglass on the case back. It's manufactured by Aristo..anyone heard of this brand? Hope u enjoyed the pictures! Anilv
