Showing results for tags 'diy watch hand levers'.
Found 1 result
  1. I had nothing better to do today, so I thought I'd make a pair of watch hand levers. I had some 3 mm tool steel rod and cut off two pieces 80 mm long. I then reduced the diameter to 2.2 mm at one end of both. One end of each was ground flat and level to just about 1/3rd of the diameter. Then, on the side that goes up against the dial, I ground the ends flat again to about 1/13rd but tapered them down to 0.2 mm at the tip. Using the round file handle as a mandrel, I heated up the ends and gently hammered the tapered side over to make them slightly rounded and also cut in a small 'V' notch, then left them to cool. When they had cooled down, I heated them up again slightly to temper them. I'll put some heat shrink tubing over the handles to finish them off.
