Showing results for tags '7009-3040'.
Found 1 result
  1. Hello, Now going to tackle my second Seiko repair after fixing a displaced 7S26-C rotor/bearing (posted in another thread). I'm still a newbie at all of this, but learning by watching, reading and doing. I'm really enjoying the work, I wonder why I did not learn this art years ago. I was given a Seiko 7009-3040 automatic for free. I took a look at it and saw that is had a bent second hand. Closer inspection showed the little [ S ] emblem has been disconnected from the face and is rolling around between the dial and the face (show here resting next to the 4 o’clock position. It was actually in the day/date window hiding at first. After a bit of tapping it came out. I was thinking it might be not too hard to fix? Separate the movement from the case of course. Then glue the [ S ] emblem back in place on the dial using a very small amount of super glue. I can see two small holes for mounting. Bend the second hand back to straight. So the real questions are is super glue OK for this application, I would assume to let the dial stay out of the case for a day or two to protect the rest from 'glue fogging'. looking a the second hand, I'm almost sure it just might break if I try to straiten it? had anyone else seen this happen, the emblem falling off and fouling the hands? Thank you very much in advance. Cheers
