Showing results for tags '7005-8020'.
Found 1 result
  1. Hi guys, Im servicing a really grimy Seiko 7005-8020 watch, and after finally getting the corroded case back off (used the classic superglued screw-nut trick) I'm stuck at the movement rubber (plastic?) gasket and metal movement ring. The just won't move. Two questions: Is there a trick getting the gasket off? It seems fairly hard, if I try to pry it it will probably break. Is it easy to source new generic gaskets for Seiko watches? I need both flat and round plastic and silicone gaskets for my ongoing projects, is it OK to just replace them with something similar of the same size?
