Hi People :)
I have an short Question maybe someone can help me out?
I am here with an Omega 1138 Despair :)
Ok let me Explain the Problem...
I have Service the Complete Movement... The Base Movement Runs nice and Strong now... But the Added DD Modul that are on is the little prob...
All at the DD Modul is Working Fine only one thing not...
When you Start the Chrono and Stop them and Press then Reset the Chrono Hand didn´t Move to the 12
I mean if you Reset them the First Time it Reset at 12 if you Reset Second Time it Reset to 12:01 if you reset again it Stops it Reset to 12:04 for exsample...
When i Move the Chronohand Freely without Press Start/Stop and i Reset them they Reset always Perfect to 12
Could it be that the Chronograph Wheel is Bad? i have check them... I can´t see any Damage on it... And the Gear self Rotate.
Second thinking was the Clutch Wheel i have check them too and seems also ok.
Or could it maybe the Clutch Spring ?!??
I hope someone have an idea!?!? ;)
Many Thanks...
