Hi all.
This is my first post for repair advice so I’ll do my best to explain what info I’m looking for.
 I have a minute repeater in a rolled gold hunter case but the stem and crown are missing.
looking at the movement it is Swiss made and operates well. I’d like to make or purchase the stem but I’ve found a crown that fits.
The case is a Thomas Russell & Son (Uk) but also marked Elgin so a US.case.
the neck (if this is the correct terminology) that the stem goes through and into the movement doesn’t have any threads either internally or externally.
My first question is, would this have a sleeve that goes in to the neck that the stem would go in to?
I’ve looked tirelessly to find info on this particular movement for information on the stem configuration but everything I’ve found differs slightly from this. Some have stems screw in to the neck and some just sit in there.
Second question, how would the stem be secured in place on this movement? I’ve found a another stem and crown and it winds well and moves the hands but it’s the wrong stem but the crown will be fine.
Oh looks like the hour hand is wrong and it’s missing the seconds hand too.
Anyway that’s it for now, there’s only so much I can digest. I look forward to your advice and hope for documentation on the correct stem/sleeve/crown  to get this beautiful watch running again.
Many thanks
mark
IMG_2359.thumb.jpeg.249851da55037cb0556d78da4424a7b2.jpegIMG_2355.thumb.jpeg.fa114d3b14e4fde15722ddc141357ca6.jpegIMG_2352.thumb.jpeg.d2cde4f23a53489dfb045473cd58e81b.jpegIMG_2353.thumb.jpeg.acd81d8faa785a96c17c5e9019db45ea.jpeg
Welcome to the forum.
Have you had the dial off to look for any markings.
When you do this can you also post photos of the keyless works along with the size of the movement.
Hi Andy. I’ve had the dial off and there aren’t any markings on it,  also I’ve included a photo of the movement minus the dial in my first post.
the dial is about 43mm
Many thanks
