I have a 1987 Mickey 2K03 5009 watch that seems as if the movement is dead.  Im not a quartz guy so was wanting to swap the old movement with a new one.  Unfortunately they are out of production and i cant find one on Casker , esslinger etc
What movement would be compatible with it?
Thanks,
Jeff
2K02A&2K03A.pdfFetching info...
As far as I'm aware there's no direct replacement for the 2K03 due to the position of the sub seconds hands.
Have you got any test equipment, even an analogue meter, to see if there's any life in it?
Edit
Just had another look through my notes and the V803 is an equivalent but also as rare as hens teeth.
Edited by AndyGSi
I have test equipment for pinball machines. so have a meter etc and probably can test.  looks like ill have to dive in  🙂
I have both but prefer the digi.  I asume i need to test the coil for ohms  somehow or if theres any voltage running thru
Well I sorted it.  I have a crown and new stem on order as the old crown is missing.  The old stem is still in the case and movement. I thought maybe the stem wasn't pushed in and was in setting mode.
Pushed the stem in and Mickey is off and running.
