Bulova Rubaiyat 1920/21
By MariusJacob · Posted
When this has happened to me, most of the times was due to a loose canon pinion. -
Poljot 2614 is a movement quite easy to find as donors thought eBay, Etsy... Really cheap. A quick search through the bay sorted by the cheapest first, shows me, as a first result, a seller who offers different pieces, plates as cheap as 6 euro plus 3 euro shipping. Complete calibers for 20 euro. And if you are not in a hurry they will show up cheaper. -
By watchsteel · Posted
movement is a Longines cal. 6651. I’ll check if the dial washer is fitted right away. I appreciate your reminder I completely overlooked such a basic detail. -
It's not actually that bad Glen. If the movement is in good order otherwise, I see no reason not to re-use this. What is the comparable barrel to unwound mainspring diameter? X3 ? X4 ?
