Best source of 1962 Omega Seamaster 30 spares( hairspring)cal.269 or 286 please
By RichardHarris123 · Posted
I read the opposite, very hard to scratch but easier to shatter. -
A replacement movement is pretty cheap. Assuming you've already tested and changed for a good battery, it's simple enough to swap it out for a new one.
