Hi!
Struggling with movement removal in Longiness La Grande Classique. Photo tells everything:
To remove movement I need to remove hands and dial only comes out front side - i.e. need to remove crystal without removal of movement.
Removed crown, and tried with syringe and o-ring but no luck - getting pressure leaks from place when syringe contacts with o-ring/watch before crystal pops (even though I feel significant pressure on syringe). Any ideas?
Nope, there's no bezel there. 3d printed tight fitting adapter and tried with 60ml syringe literally using my full arm - no luck.
Ok managed to apply enough  pressure:
 - 3d printed adapter
 - o-ring
 - BTWIN 900 bicycle pump
 - one person holding watch and adapter another pumping the pump
 - used watchmaker pad to protect the crystal (i.e. put watch on it crystal down)
Edited by Daimon
