Hello,
is there a way to figure out what size case I need for a specific watch movement and dial?   I’m currently working in a Welsbro watch which has an AS 1002 movement.   I don’t believe the case that came with it is the proper case and appears someone was filing the crown hole.  There is no tube because it’s a two piece case and there would be alot of dirt that would get into the movement because of the size of the crown hole.
Anywa, the dial and movement look great and I’d like to fit it into a proper case.  Are there certain measurements I should have when searching for one?
