In order to inspect the clutch and the clutch lever must I remove the cover plate? Are there any 'surprise' I should be prepared for; such as' beware the clutch level is under tension'? - Or is this a simple case of unscrewing the cover plate, then lifting the clutch and its lever? I am working w...
