ESA 9162 Tuning fork movement
knutos
These were made under license from bulova. But esa made some significant improvements. Anyone looking to undertake an overhaul would do well to dig up a service manual (available with couple minutes googling) and follow it. Service is quite different from a bulova. They are tractors and run for decades if not abused- like accutrons.
These are really interesting watches some improvements over the Bulova. You can separate the electronic module from the rest of the watch. There's even a calibration device built inside providing somebody put it back where they found it. The biggest challenge of course is finding parts for these watches.
So interesting video at the first link. Second link in case you lose your mind and want to service it yourself. Third link interesting pictures of different tuning fork watches and you'll notice this person services these type watches.
https://www.youtube.com/watch?v=fNUIRJsTyVw
http://www.timetrafficker.com/about/watch-care/pdf/esa-9162-repair-manual.pdf
https://electric-watches.co.uk/movement-types/tuning-fork/
Thank you for your kind answer, all above is known to me already, however I haven't been able to get in touch with the parson behind the site mentioned in link 3 yet.
So the first link is interesting You'll notice somebody is asking about the exact same person you're asking about. So on this discussion group he goes by the name of Silver Hawk Versus his real name of Paul. So the indication is if the contact page is open he should reach out to you as soon as he catches up with his backlog of watches.
https://www.thewatchforum.co.uk/index.php?/topic/120945-electric-watches-couk/
https://electric-watches.co.uk/contact-me/
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is. I've attached a lesson regarding mainsprings, focussing on the size and strength of the spring within the barrel, you might find helpful. Unfortunately it is a PDF converted from a PowerPoint presentation, but only a slide was lost that was originally a video of fitting a mainspring   Lesson 5 The mainspring.pdf
