Solid 18K Gold Lug Repair Advice
JBerry
Hey guys,
I picked up an old boxed Seiko Cronos in 18K solid gold from Japan,
I am absolutely delighted with it, however I noticed one of the lugs has a little bit of sideways play.
The bond between the lug and the case appears to be cracked, as I hope I've shown in the photos.
I'm wondering what the best way to go about this repair is, is there some kind of epoxy I could use to secure this? or is soldering/resetting the bond possible with a conventional soldering iron?
Thanks so much for the advice in advance, I know there is a lot of information available on soldering lugs online, but given that my lug is still in place, and is partially secured I hope there is a simpler solution.
I went to a well recommended local jeweller...
He advised me in order to solder the lugs he would have to bring the case up to such a high temperature that it would likely warp the case.
Is there any truth in this? Before I went in he was confident he could fix it, but made this claim based on the shape of the case.
He doesn’t want the job.
Technoflux cool paste is a heat insulation paste used to protect areas not requiring heat when soldering e.g. stones, areas of metal or solder joins. The paste is applied liberally to the area, heat is then applied (during soldering),
Thanks again OH, that's a relief. Now to find someone that does want it... is there anyone in the UK you would personally recommend?, I would be content to post this off. Otherwise I can try a few more relatively local places and the NAJ list Mark sent.
Edited by JBerry
punctuation
It could warp the case, though someone competent with a torch would have a low risk. Perhaps they've already gotten bit by picky watch folks in the past and just don't want the potential headache as OH said.
Many jewelers now can do laser welding but that won't be as strong as soldering on this job.
Ok, as a jeweler I can tell you that if this came in my store, I wouldn't secure this lug with anything other than my laser welder. Can it be soldered, probably, but no jeweler is going to want to use hard solder, so it will be done with easy solder. I can almost guarantee that the solder will flow around the crack as well as in it. This means more cleanup and being such a tight space, well, thats another reason I wouldn't use solder. Not all 18k are the same, there are different shades in color.
Lasers definitely have limitations, but in the years I have had mine, I have never had an issue with yellow gold or platinum, especially high karat gold. In the laser its like butter and produces an very secure joint. Remember that solder is a special alloy formulated for heat, while lasers use actually gold wire and basically work like a tig welder.
Lastly, if you seek out a jeweler with a welder, make sure its a laser welder and not a puck welder. These are not as precise nor as clean in their function. Here in the states anything done on the laser starts at $30.00 and goes up from there, so it shouldn't be crazy expensive.
Good luck
You are absolutely correct on this and heat shield would be a good idea if soldering is the preferred method of repair. However, remember that when any type of heat shield is used, it essentially works as a heat sink which means the torch has to be cranked up to compensate. Being that this is an 18k lug, only an experienced jeweler should attempt this. I say experienced because here in the states, there are too many "jewelers" that are amateur at best. They think they can handle something like this and what you can be left with is a melted lug.
Thanks for all the answers guys! I'm going to take the safer option of having it laser welded, a jeweller got back to me with a thorough description of how he would tackle the issue based on the pictures and a fairly reasonable quote, plus I've heard good things about him. Which is probably the biggest factor for me. Will revert back to the thread when I get it back. Fingers crossed!
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
    • Well I put the spa on Gumtree (selling service) to try and sell it as it only needs a recirc pump to get it going. However, it weighs circa 250kg, so there's 4 fairly strong guys, and I would have to remove the sliding door in the room completely to be able to get it out, as well as clearing out a multitude of potted plants and the Alfresco outdoor setting to be able to get it out. Then move nearly everything in the back of the garage to be able to push it through to the front of the house. I would also need to hire furniture skates to be able to shift it around as carrying it is out of the question. Then someone would need a trailer to get it to their place as you won't get it on the back of a ute. So, the only answer is, out with the reciprocating saw and cut it all up into manageable pieces. Crying shame as it is in really good nick. I was only asking $1,500 and only got two bites, but it would only take something to go wrong with removing the sliding door etc that everything I make on the sale could go out the door on repairs etc. It would have been nice to be able to turn it into tools etc, but que sera sera. I don't know about the rest of the world, but there just seems to be very little interest from people wanting to buy things secondhand.
