Myota watch movement
stephent
Hello,
I have an old Timex watch that belongs to a good friend.  It has a myota movement in it but as far as I can tell,  no numbers to identify the movement.  How do I go about buying a new movement when I don't know which movement it is?  Thanks in advance
If you go to the Miyota website they list every movement available with a spec diagram. They are divided into type eg 2 hand, 3 hand, multi function etc.
The difficulty comes when you don't know the height such as 2033 or 2035.
Here's the best pics I could get.  All it says is unadjusted myota Japan on it and also no jewels . Another issue is that I can not get the stem to lock in place.  I've tried turning it while very easily pushing in on stem,  pushing release,  but no luck.  Only thing I haven't done is completely taken it apart
that is a Miyota 2115 - have a look at this on ebay item number - 123203142869
here the attached pic, there is a small dimple that when pressed down releases the stem
this is a very common feature to quartz movements.
Edited by JerseyMo
more info
1 hour ago, stephent said:
JerseyMo,
Thanks for the reply.  Mine doesn't have the dimple.  I noticed a lot do but mine doesn't.  But I will double check.
not an issue now that you are replacing the movement. once the new movement arrives it will have a stem.
you only need to remove the crown and fix it back to the new stem.  Of course you will also have to size the stem.
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is. I've attached a lesson regarding mainsprings, focussing on the size and strength of the spring within the barrel, you might find helpful. Unfortunately it is a PDF converted from a PowerPoint presentation, but only a slide was lost that was originally a video of fitting a mainspring   Lesson 5 The mainspring.pdf
