Fitting a watch crystal
Hello again. Following my request for help finding a watch back the only option seems to be fitting a low dome crystal instead so the back becomes see through, curtesy of philipk5
My question is how much bigger than the actual size of the hole should a watch crystal be to ensure a tight fit but still fit in.
The diameter measures 27.8mm and as it's only a cheap watch which I want to fix as usable for my son but I don't want to spend loads of money buying a range of sizes.
Any advice would be appreciated.
Thanks, Mike
If you still find it loose and you need it to stay put.....on a cheap watch....just a tiny bit of super glue applied to a well cleaned oil free case..three or four tiny spots..so you wouldn't notice it.and the crystal will stay in place .
If the internal diameter of the case measures 27.80mm then a 28.00 low dome acrylic should be able to be fitted using a "claw". It needs to be tight enough to provide some sort of seal and not fall out but not so tight it won't fit!!.
If you use any sort of adhesive it will make removing the acrylic somewhat difficult in the future (probably next week when a proper case back turns up).
Also make sure that the crystal doesn't foul the stem &/or pushers and any moving parts.
Photos of your watch front & rear may remind someone they have something in their scrap bin?
Hope this makes sense, and helps keep another watch in use.
Cheers
Phil.
A simple cheap alternative would be to make a case back from a CD (Compact Disc)
I have a habit of stringing up CD's in the garden. After they have weathered the coating comes off and they are clear but not as transparent as a watch crystal. Also the ones I have had are 2 part laminates which easily separate after weathering. I have used these in the past for emergency crystals in cheap watches.
In this case you could use a new CD. Cut out a circle which fits tightly into the case. Cut another circle which fits over and to the overall diameter of the case and glue the 2 together. Alternatively just cut a circle which fits the overall diameter of the case and glue it on but glue it all around so to seal it. Trim if necessary with a file, sandpaper etc.
It should not scuff up as quickly as a crystal. I use scissors to cut after the CD has delaminated ie one half but I use my scroll saw to cut a full thickness CD
   the use of glue, on the crystal, will reduce the value of any watch!  if you must use it,  use epoxy,  on the bezel, because it can be removed easily  with 200 degrees farenheight.    there are many instructions on proper "crystal replacement".  vin
If you have the dimensions I can have a crystal custom made to any profile or flat, costs are at most two euros.
I also have abundance of desent european quality vintage NOS flat crystals at low price.
Cutting is done with grinding stones.
To alter one and make fit yourself. Use a razor blade to shave off the circumference down to a perfect fit.
The art of perfect fit is patience.perfect fit gathers no or minimun dirt.
The diameter is to be 2/100 of a millimeter larger for tight fit.
If polymer try heating the case , insert the crystal, keep under press, raise tempto get the polymer melt fit.
A good press insertion dose a lot of good for flat crystals.
Regards joe
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
