Mums watch - "can you take a look"
ro63rto
She asked if I could take a look.
When I turned up today, she handed me what I thought was a bracelet.
A closer look revealed a tiny watch with a dial in a bit of a poor state.
Of course she was joking but she just wanted to show me it. She claims its "about 100 years old"
Any ideas if it could be really that old.
If needs be I could try to open it up for more photos tomorrow once I've set up my new desk lamp.
MIYp8Ds.jpg&key=90f0c9cf36df0ea1263dffbe62278b0100a4fe840d5c150f4f11fa4fe83c760a
It never ceases to amaze me how small this ladies vintage watches were. They must have had remarkable eyesight.
Ok
Small update
Abandoned trying to use my new light as i had to use a macro lens on my mobile to get a good enough pic so it blocked out the light [emoji35]
Anyway, the case is 18k gold [emoji322]
zjfGz2z.jpg&key=cc3e509f102278fe6e3cfbcf0006791700afd34b3e1485af6f7a3360e8b2780c
The dial isn't as bad as it looked, it's the plastic crystal that's badly scratched.
yOhz22B.jpg&key=5dc64b6e59cce7f5c97bd1bd0ba3ba45871cd26f37442428967ba038c1a9321a
Can't see any makers marks on the teeny tiny movement though. Difficult to get a decent pic using a mobile phone [emoji26] . As I said, still ticking away [emoji106]
Trig2Mv.jpg&key=6e57c08eb4c88cbe9795c11eeef6d58d5ebab3e4b52aa727a3473b51b8e9e641
Looks like a cylinder movement. The photo is not that clear for my eyes. I’m saying cylinder because the balance wheel is not compensated. You should be able to clean that dial up, remove the hands, You need a rubber the sort that rubs away pencil marks, rub all over the dial, don’t worry you will not harm the dial in any way. It will come up a lot better than how it looks at present.
On 10/15/2018 at 2:00 PM, ro63rto said:
Hopefully I'll get a few photos today. Setting up my temporary little area for a few jobs and will try out this new light.
I have these lamps, they really do a great job, they have a dimmer and you can set warm to cold light
    • Before putting it back in the case I would fit the hands and use a pin vice on the stem to make sure the hands were in line.
