Record 1955-2 / Longines 505 auto bridge bronze bushes
Ive heard about that oil before for the lever pins. I found it easy to work on , it didn't have a whole lot of pivot wear but i bit sloppy on the lever cock, i think you have to live with what you have or bin it. Stiff to wind and set ? Not a cannon pinion issue that has no friction thats made up further back and if I remember the barrel drives the hour wheel. No problem on this one .Let me know when you start it as i have another that donated to this one, i can work alongside you with it, two heads are better than one. -
This part is dusturbing… The UK is no longer part of the Lugano Convention, whose rules Judge Green has applied, and as yet nothing permanent has replaced it.
I was not aware of that as I'm not familiar with the 861 calibre but I was speaking in general terms. Thanks for pointing it out! I thought it was somehow resting/rubbing on a very small section on top of the barrel. So, not really an exception to the rule then. Good to know!
Yes I have that in my watch list a JUF if cheap enough I will have a go , if nothing else it will be good for spares, I have a few JUF’s
