Stereo Microscope
There are three different types of stand/holder for this microscope I have seen on eBay. This one on a (sort of) rigid stand, one with what looks like a flexible gooseneck style stand and one on a tiltable suction based stand. You could therefore get one you could angle if wanted - you may even be able to buy the stands seperately as the microscope is the same.
Stephen
Hi Transporter  got on of these my self and right handy they are for the close up inspection, They dont cost too much either. I got mine through and english based seller at£35.76p, delivery was quick enough and arrived intact, got to get an sdcard and play about with it a bit quite brilliant for the cost.
Gotta say I’ve been looking at microscopes for awhile but price has been a tad high, buying this was a gamble but it paid off, as like you say it’s very handy for those inspections, I’m extremely happy with it!
Just used mine yesterday do some  close up Really close up jewel inspections on a pocket watch.
ok yes I could of used a loup but these things are fantastic, I had a jewel that was broken in such a way it was like it was too big for the pivot on the escape wheel, no cracks it just looked like the centre had come away, or maybe it is just too big a jewel!!!!! Anyway I know I need a new one, hopefully might find the correct size in my spares.
I got many vintage watches mainly Oris, pin lever with metal pivot hole, . I posted a topic several months back title" those vintage Oris watches that stop working several months after cleaned". I received advices and
learned worn out pivot and pivot holes is among many culprit for such movements, So I thought I need a microscope to see the wear in pivot holes and on pivots as well.
Am I right assuming a microscope is best tool for revealing wear in pivot holes?
Is there any more suitable tool for this purpose?
What type of microscope digital or conventional lenz be most suitable? And what resolution would work  best.
Thanks in advance.
Regards n9é
I have two microscopes one over my lathe and one on my workbench. They have become an invaluable tools for me because my eyesight is not  good. Inspecting jewels, pivots, manipulating hairsprings and turning down small items on my lathe would not be possible for me without them. They were both purchased second hand the one on my desk is a Olympus and the one over my lathe is a Bausch & Lomb.
Thank you Sir,   A microscope good for checking the pivots and pivot holes for wear suits me. My eyesight too, is poor. Some complain the electronic microscopes they bought are good as toys,  I think high resolution and magnification are the effective factor, am I right? And if so what range or degree of resolution is required or recommended.
I am not experienced with optical microscopes either.
I need tech specifications of what is recommended. What is the right choice for my intended use?
I don,t intend getting into lathe or other machining.
Regards joe
Most useful is a stereo zoom, a nice Wild or Meiji or B&L is just the ticket.  i pick them for cheap when they appear on the classifieds, have 4 so far (last one, a B&L came up for $25 with a microtome....I couldn't dial the number to say I'd take it fast enough).  They by far give you best image and resolution.  However they are very expensive new and it can take more than a month of Sundays to wait out the $25 one.  The digitalis main advantage is cost, a nice one is $100, and the quality has for sure gone up.  Magnification over about 50x isn't much use (about the max of a stereo mic) with watches, imo, so if you are selecting one with range, try to get one who's range goes well under 50.  i.e. 10-100 would be great, 100-500, about useless or close thereto
I use a standard but modified pine desk which is painted white and covered in white vinyl, an adjustable stool which gives me just the right height. The movement or movement holder would be about 22cm from the front edge of the desk which is lipped at the front to catch  (most) airborne springs and screws. I can work for hours without back or eye strain but whatever arrangement you have I think regular breaks are important
