Case back opening.
philipk5
https://www.amazon.com/Opener-Stainless-Professional-Adjustable-Remover/dp/B01K7ADWWA
 This is the most widely used adjustable wrench.
You may find the back hard to turn and open, due to dirt ...etc,
 Watch oil or auto brake fluid or B12 applied generously around the rim of the back and letting it soak over night is helpful and normally adequate.
Regards joe
Thanks for all the comments.  It's not a conventional screw back - there are only four notches and an inscription for open and close. There is a very small amount of (very free) movement of about 5/10 degrees. I assume that a small turn and the back would drop off, but it doesn't and I am reluctant to "persuade" it until I have a better idea of exactly how it should come apart and hence then working out why it doesn't.
Bonus points to clockboy and eezyrider !
Managed to open it. Apparently there are three lugs on the case back that are equally spaced and locate with corresponding notches on the case. Very easy to go past the opening point and as such re-lock it (Japanese sense of humour??).
Here are some photos to clarify, also for future reference should anyone encounter one. Assuming this isn't the only one still in existence.
Many thanks to all.
Now just need to track down a replacement movement...….
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
