Thanks guys for your resposes. @Nucejoe, the movement is a Zim 2602 with a fixed stud. Here are some pictures of the balance and stud itself. As you can see, the stud hasn't come off - it's just flopping around all over the place. I can flip the stud to lean the other direction and take the same picture. Do you guys advise removing the pin and starting from scratch, or just trying to push the pin back in? And yes, I know the pin looks super weird and rough here.
You measure the diameter of the barrel and it's inside height.
The main spring is snapped! 😪 Not sure how to go about finding a replacement, is by length? Any idea how to measure the length of the coil? The inside diameter of the barrel is 16.9mm, the spring is 2.5mm wide and 0.2mm thick. Obviously, being a fusee it has no return like modern springs, its just a straight coil with a hole on either end.
The bike is now all finished although I will replace the brake leavers when I can find some more in leeping with the age of the bike. I took it for a short test ride tonight and the Sturmey Archer hub is changing gears nicely and no slipping when riding up hill. I'll take it for a longer ride this weekend.
There is also the possibility that it would require the glass to be removed using a glass pump as is the case with monocoque cases.
Question
philipk5 15
Any advice on opening this case back would be appreciated.
Thanks in advance!
Link to post
7 answers to this question
